what do you mean by air intake? Yes the pipe you have circled connects to the throttle body and is part of the intake piping.
That is not stock, it is a very neat aftermarket jobby, looks like a factory VLT crossover pipe has been chopped and had aftermarket piping welded to it, with the whole lot painted black. With the fact that they have done this and kept the factory airbox, and factory VLT heat shielding makes it a very neat impressive R31 turbo conversion.
https://www.sau.com.au/forums/topic/305005-r31-intake/#findComment-5048813
Ijust recently bought an R31 skyline, and i was just wandering if i could put a pod filter on the end of that pipe?
https://www.sau.com.au/forums/topic/305005-r31-intake/#findComment-5048852
Is that a picture of your cars engine bay?
If so, that car is turbo, and if you put a pod filter there, 2 things will happen. 1. you car will become a hell of alot slower, i.e. bcome n/a. 2. you car wouldnt actually go, because the AFM wouldnt meter the air going into the engine to tell it how much fuel to inject.
If that is your engine bay, i really wouldnt recommend putting a pod filter on it, yes you will get some cool noises out of it, but it wont positively effect performance, infact, at higherspeeds, you will notice a drop in responce and general pickup (spool, getup and go) due to losing the snorkel.
If that doesnt change your mind, then what you need to do, is remove the airbox.
To do this ,you need to pop the clips on it, pull the top off, pull out the panel filter, unbolt the afm from the airbox (bolts inside the airbox, with a metal bellmouth) then unscrew the airbox bolts ive circled, to pull the whole contraption out.
Then you need to take the metal bellmouth or airbox bottom into somwhere like autobarn or supercheap, and ask for an AFM pod filter adapter to bolt to your afm. Then your in buisiness....
https://www.sau.com.au/forums/topic/305005-r31-intake/#findComment-5048889
No that isn't a picture of my engine, i haven't got a camera and i lost the cord for m phone to plug into the computer, basically i want to know how to put a pod filter on a N/A rb30?
https://www.sau.com.au/forums/topic/305005-r31-intake/#findComment-5048921
Its the same story for your car, for the info i previously gave.
All it will give you is the induction noise, there will be no power gain, infact there will be a slight loss at higher speeds and lower ambient temps.
So i have to install a cold air intake yeah?
how much would it set me back by doing so?
https://www.sau.com.au/forums/topic/305005-r31-intake/#findComment-5049361
ah yeah i know this car....its currently for sale >
http://www.carsales.com.au/all-cars/privat...id=123AB1F0900B
CAI shouldn't set you back too much you just need the material to make a surrounding for the pod filter, or alternatively you could buy one pre-made.
check out r31skylineclub.com, i remember seeing a DIY section for cold air intakes and photos of everybody's different designs etc..
https://www.sau.com.au/forums/topic/305005-r31-intake/#findComment-5049420
Gee, that engine bay looks familiar... Thanks for the comments guys :P
Currently worse for wear after some Victorian dickhead in a rental chucked a U turn infront of me... 3 weeks later and the assesor from the Rental company is only just looking at the car today, and not in person I might add. I have offers on the car as it sits, and if I get a settlement payout, the car is going, and I'm keeping the cash.
As said by many others, its a turbo setup, sticking a pod on the end of that section of piping will do more harm than good, again check out R31 SC for all the details about doing that. I know plenty of people who run with the lid off the airbox, works well on the turbo too - Great flutter... or have a pod in place of the stock airbox. Personally, the stock airbox is quite ok.
https://www.sau.com.au/forums/topic/305005-r31-intake/#findComment-5060002
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
