Hi,
I purchased a Trust Return Flow FMIC off a member on this forum and was about to start fitting it up this weekend. Just started reading through the thread in the FAQ section and it mentions cutting the reo and bumper bar (although it is a different style of return flow intercooler).
http://www.skylinesaustralia.com/forums/In...Fm-t288799.html
Also the one in the thread has a slightly larger cooler: 620 x 266 x 76mm
Where as this one is (Trust FMIC Return Flow): 520mm x 250mm x 70mm
Also it doesnt have the pipe running along the bottom of the cooler like the one in the thread does.
Has anyone fitted a Trust FMIC Return Flow? Did you have to cut anything?
Any help much appreciated as it will save my many hours of work as I really dont want to cut anything. Thanks.
Edited by Harey
i think your confused - the point of the trust return flow, as the name implies, is return flow
that is, it re-uses the stock intercooler piping, so you dont have to cut anything
I am not talking about the cutting for new intercooler piping, I am talking about cutting just to fit the physical cooler in. If you look at the thread in the FAQ, he has a return flow intercooler and yet still has to cut both the reo and the bumper to fit it (although it is a different size cooler and different way of running the pipes back to the standard intercooler piping).
Edited by Harey
If it's a return flow cooler it MUST have a (not permanently attached) pipe running along the bottom/top of the cooler core, hence the term return flow. This doesn't mean you don't have to cut anything to fit the intercooler core though...just that you don't have to cut holes for the piping because the supplied pipes will connect up to the existing side-mount plumbing. It's the intercooler core that gets in the way of the REO and in 90% of cases I've heard of people cutting their REO bar and front bar. It doesn't need a great deal of cutting.
If the person you bought it off sold you it without the bottom pipe, I'm assuming here, but maybe they damaged the bottom pipe hence they got rid of the intercooler? Or they lost the part? Shouldn't be too hard to locate another one or get one made up.
Most likely you will have to trim the reo a little and some of the bar cover, the bar cover trimming should be at the back so will not be visible unless you want to cut the centre section out for more flow to the core.
If you do not have the pipe running along the bottom of the core then i doubt it is return flow.
This design does not have a pipe along the bottom:
http://www.skylinesaustralia.com/forums/Tr...ust+return+flow
I am wondering if anyone has fitted this particular type of cooler, but its not sounding good. I dont have any equipment to cut it even if I decided to.
Ok that's a turn flow cooler, not return flow. Difference being what Brett pointed out. I still think you'll need to cut the reo just to fit the core, but you won't know until you test fit. Solution: pull off your front bar and test fit to judge how much you'll need to cut (if anything), you've got nothing to lose and it doesn't take that long. The cutting and permanent mounting of the cooler is the time consuming part.
I fitted a Trust Turn flow intercooler to my Stagea and definitely needed to trim the Reo bar maybe a 1-2cm to prevent it hitting the top of the intercooler. I imagine this is typical with all of the Skylines / Stageas as there is not enough room behind the Reo bar otherwise. I don't think there would be any way to avoid doing this unless you are running a seriously thin intercooler. Even then you would probably need to remove the Fan that sits behind the intercooler as this protudes slightly.
Hi,
G`day ,I fitted front mount to my Stagea Blitz`s type,now you will need to mod Reo but don`t cut it OUT just Mark & slot REO THEN BEND IT UP so it will fit no need to CUT IT OUT ,& if you want to remove it just fold it back & get it rewelded all sweet you will not know,Good luck Chuckie.
Bending it = just as defectable and probably more noticeable than cutting it...I'd be doing a neato cut job of it and spraypainting it for a stock appearance :D
Ah ok subtle but important difference. That makes sense now.
If you are talking about the cooler in the photo, that would be a 'return' flow intercooler :D
Thanks for the info! I am really fussy and dont have to install the cooler, so I will be putting it up for sale.
i know someone with one of the trust turn flows. it was on the car when they bought it, but whoever installed it cut the whole midsection of the reo
away. though not needed i would think.
i've got a jjp return flow, and yes you need to trim or bend the reo so the core fits in there.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
