Hi all looking to buy an GTR R32 as it's the look i like most out of the GTR'S just trying to do research first before seriously taking the next step and buying one, power wise i'm not really wanting to go more than a better fmic, exhaust, and a bit more boost maybe a little large huffers i do have a motec m48 not sure at this stage if that is worth keeping it for the GTR?? as a lot of guys seem to use power fc's? and since the R32 is a lot cheaper these days makes it a good time to find what i'm looking for and at a decent price.
so any do's and don'ts on what i should be looking out for in the R32 GTR i've read that the pre 92 model had issues with the oil pump which was rectified in post 92 models also i like the fact that R32's can be switched from awd to rear wheel drive by replacing the fuse with a switch, just a couple of things i've read so far so any more help on buying a GTR would be much appreciated.
Also what i would like to know is what type of internals from factory does the RB26 in the R32 GTR come with ie: forged rods? forged slugs? ect.. is there a book on the GTR with such info? and most importantly are the five speed gearbox much stronger than a WRX one as the wrx gearbox really lets it down once you up the power somewhat.
PS: only looking for a reliable daily driver with about 260-280kw atw
regards wayne
https://www.sau.com.au/forums/topic/305046-beginners-info-needed/
People will say look for a post 89, 90, 91, etc.
Basically the newer the model the better the condition should be.
Not totally true.
I've seen 94 examples that looks more shocking than the first bunch that came out in 89.
Before I got my R32 GTR I avoided 89 models because being the first years I thought they may have some initial teething problems as with any first year models. However, if there was a problem then most if it should have been already rectified by their original owners anyway.
That said, getting a latter model would usually be better.
the skyline gearbox is bulletproof in comparison to the wrx gearbox
you wont have any issues with gearbox even with abuse
make sure you have some spare $ on the side in the case of other issues, gtr's can be costly
When you think you've figured out how much it will cost to fix any issues you've found, add approximately 30-500% for all the other unknowns and remember you pay the GTR tax on all parts.
They're not a cheap car to own, even if you do all of the work yourself.
On that note, I love every single minute I spend in mine. Well worth it.
Edited by Bozz
Yeah i figured that as my last car was a jap legacy import, genuine parts were at crazy prices, but cars are our passion and i dont know anyone who finds there passions cheap, besides you only live once.
PS: i hear ya about loving every minute in your ride i'd say thats passion wright there :D
cheers
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
