The 2010 Villis "friday Night" Thread
Matty 31
 Share
What time did you leave? I got there at 7:50pm (got held up by various things) and within 10 minutes Blazk, RubyRS4, jrm, MattyT, Luke_ENR34 and HESLOS+1 + gf had rocked up. Good times.
i got there to early :)
anyway im back home now
gotta catch up of the homework :D
I generally get there about 6:30pm if I leave after work, everyone else turns up around 7-7:30pm
Nice seeing your all again. Love the bike Roo made me want to get one again :) .
Bring the noise! :P
On the way home, some cops took a long hard stare at me :D
"sorry? ... I can't hear you!"
well i rocked up , had a pie and left didnt see any other skylines
although got raped on the freeway by some ford fiesta :D
same, saw a black stag and a 33 i diddnt know pull up as i left, possibly you? i was there 7:15- 7:35... then gotta call about beers and backyard cricket so i diddnt hang around
yeah i just rocked up when you left
i saw your rig and was like
thats the dude from SAU! :D
Bring the noise! :P
On the way home, some cops took a long hard stare at me :P
Oh maybe the same cops that flew past me....no lights, just thought they would be commy hoons...
I wont be making an appearance tomorrow, think ill be in hiding for awile bit short on the gold coins
i shall be coming down tomorrow if i get all other stuff done in time....zoidberg your not coming to say goodbye/adios/hasta la vista/au vevoir/auf Wiedersehen to me :ninja:
i shall be coming down tomorrow if i get all other stuff done in time....zoidberg your not coming to say goodbye/adios/hasta la vista/au vevoir/auf Wiedersehen to me ;)
ill see what i can do, might mosey on over if i get out of work early enough
:P
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
