Depends on the state too - check your states registration authority website for details. If it's illegal you can get defected for it, not to mention it can be dangerous to yourself and other drivers..
Merry Xmas!
https://www.sau.com.au/forums/topic/30513-tinting/#findComment-618338
funny thing this as i was just talking to a mate last night about this, i've been to a few tint places here on the coast and they all have lets say 10 different shades on display the problem is only the lightest three shades are legal???, got prices on the darkest legal tint (not as dark as you may think) and for the same 3M tint the price range from 200 to 280 that included the removel of the old tint though, this is in QLD so may be different in your state!
https://www.sau.com.au/forums/topic/30513-tinting/#findComment-618352
mind you skylines come stock with a 95% VLT tint on all the glasses stock. so that 1.05 x the strength of tint you're getting as a quick value.
eg:
minimum VLT is 35% so (ie you are allowed to block 65% of the light) you'd want a film that block 61.9% of the light (because it will be made darker by the factory tint already on the glass)... so you're looking at a film that is rated at 38% - 39% VLT to stay legal.
https://www.sau.com.au/forums/topic/30513-tinting/#findComment-618386
You've got it the wrong way around funky...
35% tint means you're letting in 35% of light.
5% tint means you're letting in 5% of light.
All european cars come with factory tinted glass, that is, the GLASS ITSELF is tinted, like you're talking about above. But they all have a 35% tint option off the showroom floor, and they just slap a 35% tint on there, making it darker than 35% permitted light.
I think the actual limit is 30%, which is why most window tinting places sell 35% tint, to take the factory glass tinting into account.
https://www.sau.com.au/forums/topic/30513-tinting/#findComment-618389
Visible Light Transmission... so you take 100% of the light and you allow 35% of it thru... that's what 35% VLT means.
A factory glass tint is 95% VLT as it blocks 5% of the light from goin thru.
And yeah I think the limit is 30%, but I've found that in adelaide this is stated in the rules, wheras in VIC its stated as 35% in the docs, so I think it varies from state to state.
https://www.sau.com.au/forums/topic/30513-tinting/#findComment-618404
meh I think I OD'd on king prawns... I was so happy too that I was havin a chinese Christmas lunch, so I wouldn't have to eat half cooked barbequed prawns... instead I get oh so orgasmic sechwan prawns, sweet n sour prawns and prawns with baby bok choi... oh my stomach feels funny but my pallette's in nirvana...
but I digress... yes... 30% VLT tinting is bad m'kay
https://www.sau.com.au/forums/topic/30513-tinting/#findComment-618414
I just got mine tinted not long ago and I think it is 35% on the side windows and 20% at the back windscreen.
My mate mentioned that the back and the quater back window doesn't really matter and you can go has dark as you like, it is just the two front side windows you get dicked for. So I'm going back and getting another layer added on to the back and the side quater windows :)
https://www.sau.com.au/forums/topic/30513-tinting/#findComment-618646
can anyone beat a price of 180? becose if not im goin to memphis, thanks
Hey i reckon $180 is pretty good, lowest i got quote is $210. How dark is this tint and wat warranties does it come with?
And i assume this is for the whole car rite. And its a R33 line or a civic?
Cheers :D
https://www.sau.com.au/forums/topic/30513-tinting/#findComment-618828
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
