New S15 Lights
Apexi, though I'm not comfortable with setting the idle, knowing me I'll f**k it up lol.
What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about. -
Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
