Hello,
I ask on this forum because there's so much people on here I'm sure some peoples can feed me some infos about this kind of setup.
I want to install an open-valve on my exhaust line to gain more power on the high-way and track. I really want a quiet ride when cruising in the street but would like something more agressive on the highway or for drag night.
So, my mechanician told me that one of his customer gain 60whp with that kind of valve. I guess he install a Y pipe before the catalyser but I can't be sure..
Feedback!??
https://www.sau.com.au/forums/topic/305152-by-pass-valve-on-the-exhaust/
Load of shit. Your mechanic needs the sack :)
If you have a decent, well contructed and flowing exhaust - then dropping it (or bypass) should see little to no difference in power at all.
You can have a quiet exhaust, and free flow, and make 350rwkw easily. It just costs money as you need decent mufflers.
....oh ok. Sounds like a lot of f**king around for no point really.
My mate had something similar but a lot more practical. A normal exhaust with a screamer plumbed in and a section before the cat that unbolted and turned the screamer into atmospheric. Took 10 mins to swap the little Y section. Was done purely for being able to have the sound for track work/fun on the street but probably made a little bit of a performance increase due to not having to run all the gases through the exhaust.
If anything maybe the OP should do something like this.
This is exactly the result I'm looking for because I will be sad to never heard back the sound of my RS*R GT2 ( but it's tooo loud for street).
By the way, it would be an electric valve, just like this one ( excepting the Apexi is mechanic):
http://www.nengun.com/apexi/exhaust-control-valve
Hmm like i said seem's like a lot of mucking around and a bit of money involved in fabricating it all and buying the electronic valve. Personally i would just do what my mate did, not as convenient cause you can't swap it from one system to the other while driving, but only takes a few minutes to swap the section of pipe in the garage.
I have a universal varex muffler underneath my car with the electronic valve control to make it quite if need be, but i'm going to get a straight 3" pipe to replace it if i want to. The muffler is quite bulky and heavy as hell and im sure it would still have a restriction on it even when fully open.
Edited by PM-R33
Hello,
Feedback!??
WTF is a mechanician???
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
