If you're looking for a straight, unmolested AWD Stagea Turbo, with the super-refined NEO engine, you've just found it.
PRICE HAS BEEN DROPPED BY $1,000, AS OWNER IS GOING OVERSEAS IN EARLY FEB.
See it in all its glory here:
http://www.carsales.com.au/all-cars/privat...9&silo=1011
Comes with 6-stack CD & cassette player (plus Jap-spec satnav & TV), 4 excellent silica tyres, Xenon headlights, foglights front & rear, floormats & more.
It's got the TIPTRONIC AUTO transmission with shift-buttons on the steering wheel & runs like a dream.
Imported by the current mature owner in 2007 with 82,000km on the clock, it's only done another 25,000 in all that time.
It's been pampered & looked after as the second family car. Has never had mechanical problems, but has had a NEW CAMBELT installed, saving you heaps. The best synthetic oils have always been used. Service records since purchase are available, as well as all the import documents.
I don't want to sell this car, but the family has outgrown it & there's pressure from Mrs Laptop.
Located in inner Bayside Melbourne.
If you want a great reliable wagon or the basis for a high-performance sleeper, you MUST see this Stagea.
Call Rob on 0408 579 313 anytime.
Drive this car & you won't be disappointed.
Edited by sven laptop
