So i finally took steps towards shielding my pod today
headed to bunnings in search of perspex
i was appalled when they wanted $45 for a smallish sheet so i bailed
buttttttttt............ on the way out i noticed they had plastic buckets for the princely sum for $0.94 so i thought to myself "what the hell...lets see what happens"
One bucket
Cut down one side of the bucket like so
See, all the way down
Looking good...but needs trimming
Trimmed slightly
Hole for the pod filter
Trimmed more
Trimmed bits
I think we're done
Yeah, thats gotta be better than a poke in the eye with a stick :(
I know its not high tech but its better than having a pod soaking up all the heat from the turbo and it cost less than a dollar
let me know what you think
https://www.sau.com.au/forums/topic/305214-toms-94%C2%A2-heatshield/
Step away from the bucket please :) .
Your car deserves better than this, what did it do to warrant this punishment?
Check out some plastics suppliers or use some flat alloy sheet.
I'd rather a poke in the eye, then I couldn't see what you've done.
Throw that abomination in the bin and let us never speak of this again.
Cheers, Dale
  • Like 1
f**k i thought i was being harsh.honesty is the best policy dale
Sorry if I offended you Tom, clearly you have excellent taste in cars, you're obviously having an "off" day.
It happens; I had an "off" day once, in the early 90's and ended up driving a Triumph :) . At least your mistake only cost 94 cents...
But please, take it off, it makes the baby Jeebus cry.
Cheers, Dale
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
    • I could see someone trying this to save money on oil changes.
