So i finally took steps towards shielding my pod today
headed to bunnings in search of perspex
i was appalled when they wanted $45 for a smallish sheet so i bailed
buttttttttt............ on the way out i noticed they had plastic buckets for the princely sum for $0.94 so i thought to myself "what the hell...lets see what happens"
One bucket
Cut down one side of the bucket like so
See, all the way down
Looking good...but needs trimming
Trimmed slightly
Hole for the pod filter
Trimmed more
Trimmed bits
I think we're done
Yeah, thats gotta be better than a poke in the eye with a stick :(
I know its not high tech but its better than having a pod soaking up all the heat from the turbo and it cost less than a dollar
let me know what you think
https://www.sau.com.au/forums/topic/305214-toms-94%C2%A2-heatshield/
Step away from the bucket please :) .
Your car deserves better than this, what did it do to warrant this punishment?
Check out some plastics suppliers or use some flat alloy sheet.
I'd rather a poke in the eye, then I couldn't see what you've done.
Throw that abomination in the bin and let us never speak of this again.
Cheers, Dale
  • Like 1
f**k i thought i was being harsh.honesty is the best policy dale
Sorry if I offended you Tom, clearly you have excellent taste in cars, you're obviously having an "off" day.
It happens; I had an "off" day once, in the early 90's and ended up driving a Triumph :) . At least your mistake only cost 94 cents...
But please, take it off, it makes the baby Jeebus cry.
Cheers, Dale
    • Found it thanks, the front tie rod end should be torqued to 40nmish
    • Ok I thought my allow had a flat back but it does have grooves for the spacer nut/ no cutting needed   bolt and nut sticking out from the spacer around 12mm and the groove is around 24mm so all good   appreciate the help chaps
    • Back in 2016 bought a set of front and rear bracket set and changed all 4 corner discs and caliper   i was checking the car and seen rust like or in another word crumbled part of the bracket which came off with a air blow   is this normal? This had happened in two areas and car from 2016 has mostly been in garage/ doing less than 2000 miles over past 8 years or so pic with areas highlighted in red   https://ibb.co/NtmWXZt   also anyone knows the torque spec for the bracket as want to retorque them, one bolt had come off half way !
    • So if I was to spend 400r money and remember I am only here because I need 4 doors because of an incoming kid otherwise I would be looking at a lexus RCF what am I loosing out on other than fuel economy but gaining in power and space / V8 sound on Chrysler 300c STR Vs nissan 400r?, I will admit that buying the VE bomadore was an eye opener into build quality compared to Jap cars... https://www.carsales.com.au/cars/details/2020-chrysler-300-srt-core-auto-my20/SSE-AD-18201088/ but this one is on the same money...
    • If you're friendly with a workshop that has a large scraps bin you can always ask to dispose of there. Otherwise theres always the places like sims metal etc depending where you are at https://recyclingnearyou.com.au/cars
