Bang for buck its got to be better value than an ARC airbox...
God i hope you don't believe that. That 2mm thick bit of plastic with next to zero thermal insulation that is just sitting around the pod wont do a single thing. If it drops air intake temperatures by a couple of degrees i would be impressed. Air moves believe it or not and will simply raise the temperature of that bit of plastic until it is the same temperature as the under bonnet temps. However regardless of that, the bit of plastic isn't completely blocking the engine bay heat to the pod, therefore air will simply move around it and the pod will still suck in hot air once again making that shield do nothing.
No disrespect to the OP, people giving things a go to save some money is fantastic, but to think that is actually doing anything is just silly.
Edited by PM-R33
If some one goes to the effort of doing that, taking heaps of pics, posting it up and then asking people what they think than yes i assume the guy is being serious. I have seen a lot dumber shit on these forums done by people that isn't a joke.
Edited by PM-R33
f**k you guys are funny
went on the nissan cruise yesterday, its still in there i think so it hasn't melted away
yes its prob not doing anything but hey, its was 94 CENTS, was worth a go and everyone got a laugh out of it
of course its not gonna seal up as well as something like a jjr carbon shield or an arc air box but my car came with the pod already on it and i didn't get the stock box with it either :rant: eventually i'll track one down or get a more permanent one but it was 37°c today and coolant temps were up to 90 on the fly so i can only imagine what the engine bay temps were like
i understand airflow and the concept of high and low pressures (i'm doing naval architecture at uni = hydrodynamics etc) and it probably has a bigger effect than you would think and it certainly can't have a negative effect as its surrounding 90% of the pod around the sides, it still made good power and i was keeping up with a 32 gtr and an s14 through the twistys
so in summery, yes its light hearted, no im not that serious about it but it seemed to work ok
As long as it worked, that's all that matters.
well i have no less power than b4 and i still get good fuel consumption (ecutalk display) so its not got a negative effect
For all those that read other parts of SAU and dont want to bitch and carry on,
http://www.skylinesaustralia.com/forums/Ca...hl=cold+air+box
Pull the tampon out and grow a pair people.
Edited by dirtyRS4
im no techo and i am sure that he thaught it was a good cheap alternative.top points bro for having a go.
+1 from me
I feel like doing it with a MeTaL bucket, probably $4.95
felt the unshielded pod before after the missus had the stag, very hot.
time for a heatshield - again.
previous unit wont fit due to my hard intake pipe setup going to the gt3076iw
so, Im going to replicate the effort and see how it feels
well for australia day i thought it would only be fitting if my turbo car was complete with flutterzzZZzzzzz
i will add this here cos i used part of my bucket waste, so this is multiple mods with one cheap bucket
basically you need to take off the stock bov which is 2 12mm bolts, 1 hose clamp (return line) and 1 hose clip (manifold signal)
then you use the gasket as an outline for a solid sheet of bucket, i.e. not leaving a hole in the centre of it
re install with the extra plasic gasket in place and your away fluttering like there is no tmrw :D
like so:
note: i take no responsibility for your actions and this is only for a short term period of shits and giggles
    • PRICE  : $1400 LOCATION   : NSW Central Coast FIT  :  All Nissan 350Z type Z33 and Infinity G35 Coupe. See delivery note. Hi, brand new, unused, still in the box.  ($1850.00 is what i paid ) My bad luck !!! I thought my right front  Bilstein was cactus so i bought the ST 's to replace all.  Turns out the right front is fine ( loose mounting after service  by a well known importer of Bilsteins ) So im selling the ST's. They are made by KW ( no intro needed ) . Iam on the Central Coast and im willing to meet up in Sydney metro, within reason and Newcastle.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
