i know its a silly question coming from a skyline driver like myself...but DAM!! skyline are fuel munchers arent they? anywayz..Is there any tips on how to save fuel? while driving?? maybe its gotta do on how u drive it? lol.. feel free to post
https://www.sau.com.au/forums/topic/305219-how-to-save-fuel/
^^^ correct + state of tune.
And don't forget our dear Rooster friend, living in Sydney where there's stop-start traffic, it's such a pain on the pocket to get around.
Sydney half the time is gridlock - not just at peak hour.
Do you have a daily for city travelling? If not... well you know the rest of the story...
PM-R33 is in Townsville.
My car runs around the Blue Mtns.
My mod collection is not huge, but with a well-tuned HKS F-Con Pro-V ECU I get 450Km/tank quite easily incl. occasional squirts thru the hairpins.
Soft right foot, don't hit hard of the lights, drive like somethings about to break.
Around Surfers I get 450-500 a tank with the odd get me outa here squirt, more if I do some highway, shit loads less if I boot it everywhere.
get an apexi avcr or a data display thing and drive it to the injector pulse the lower the better . has made a difference to mine . just interesting driving up a hill and wondering if what used more gas
5th gear 0 on boost gauge 2500 rpm =8% duty cycle
4th gear -250 on boost gauge 3000 rpm =10% duty cycle
5 things to use as little fuel as possible;
* Use the highest gear the engine will pull without lugging, and get into it as soon as possible
* Use the smallest possible throttle opening you (and other traffic) can stand for acceleration, and as few revs as possible
* On the open road, do all that you can to conserve momentum. Never let yourself speed up and slow down constantly.
* Cars use the least L/km the slower they are driven. Even more reason to stick to the speed limit.
* Replace your air filter before it gets cruddy, to maximise engine efficiency
And if you really want to save on fuel costs, get the car converted to run on liquid LPG injection
5 things to use as much fuel as possible, after all you DID buy a skyline, not a blouse...
* smash the loud pedal
And if you really want to save on fuel costs, you are ghey and should buy a prius like joeyjoeetcetcetc said
fixed
* Use the highest gear the engine will pull without lugging, and get into it as soon as possible Correct
* Use the smallest possible throttle opening you (and other traffic) can stand for acceleration, Not strictly cotrrect. A throttled engine is less efficient than a non-throttled engine. Big throttle opening at low revs is more efficient than smaller throttle openings at higher revs to give the same power. and as few revs as possible
* Cars use the least L/km the slower they are driven. Even more reason to stick to the speed limit. Again, not strictly correct. The most efficient will be the slowest the car can comfortably travel in top gear. The wind resistance only starts to have a big effect over about 60km/h
Most important factor and I can't believe nobody has mentioned it - avoid using brakes unless absolutely necessary. On the surface it sounds silly, but when you think about it, by the time you apply the brakes, you've already used too much fuel to get up to the speed that you need to use brakes. If you modify your driving style and think ahead, it's surprising how little you need to use the brakes. this means you're using far less power to get up to speeds where you need to apply brakes. No, it doesn't mean driving everywhere at 20km/h, either.
Also, if you think that knocking it into neutral to coast down hills is saving fuel, think again. Modern EFI systems shut off fuel altogether with 0 throttle and revs over a certain RPM (usually something llike 1800). If you coast in neutral, then the engine is being fed fuel just to keep it running, whereas if you're in gear, then the fuel system shuts down completely.
Follow some of these techniques and you can save a reasonable a mount of fuel. Just because you want to drive a Skyline doesn't mean you have to drive it like a dickhead all the time
new oxygen sensor - ask for one for an n14 sss pulsar (sr20) has the same plug as a 33 too so no cutting
get an ecutalk display too - i got one for my stag, plugs into the consult port and once you input the injector size it will do instant fuel consumption, read off every sensor the ecu has and do lost of things
www.ecutalk.com
Ride a bike. No, not because you drive the car less, so you lose weight and have less to push around. Of course, that's not going to have a huge effect.
Optimum speed is probably going to be 60-80km/h
If your weight is around 200-300kgs it might!~
www.ecutalk.com
Hmmmm i mite get that...so what exactly does the ecu does again?
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
