i know its a silly question coming from a skyline driver like myself...but DAM!! skyline are fuel munchers arent they? anywayz..Is there any tips on how to save fuel? while driving?? maybe its gotta do on how u drive it? lol.. feel free to post
https://www.sau.com.au/forums/topic/305219-how-to-save-fuel/
^^^ correct + state of tune.
And don't forget our dear Rooster friend, living in Sydney where there's stop-start traffic, it's such a pain on the pocket to get around.
Sydney half the time is gridlock - not just at peak hour.
Do you have a daily for city travelling? If not... well you know the rest of the story...
PM-R33 is in Townsville.
My car runs around the Blue Mtns.
My mod collection is not huge, but with a well-tuned HKS F-Con Pro-V ECU I get 450Km/tank quite easily incl. occasional squirts thru the hairpins.
Soft right foot, don't hit hard of the lights, drive like somethings about to break.
Around Surfers I get 450-500 a tank with the odd get me outa here squirt, more if I do some highway, shit loads less if I boot it everywhere.
get an apexi avcr or a data display thing and drive it to the injector pulse the lower the better . has made a difference to mine . just interesting driving up a hill and wondering if what used more gas
5th gear 0 on boost gauge 2500 rpm =8% duty cycle
4th gear -250 on boost gauge 3000 rpm =10% duty cycle
5 things to use as little fuel as possible;
* Use the highest gear the engine will pull without lugging, and get into it as soon as possible
* Use the smallest possible throttle opening you (and other traffic) can stand for acceleration, and as few revs as possible
* On the open road, do all that you can to conserve momentum. Never let yourself speed up and slow down constantly.
* Cars use the least L/km the slower they are driven. Even more reason to stick to the speed limit.
* Replace your air filter before it gets cruddy, to maximise engine efficiency
And if you really want to save on fuel costs, get the car converted to run on liquid LPG injection
5 things to use as much fuel as possible, after all you DID buy a skyline, not a blouse...
* smash the loud pedal
And if you really want to save on fuel costs, you are ghey and should buy a prius like joeyjoeetcetcetc said
fixed
* Use the highest gear the engine will pull without lugging, and get into it as soon as possible Correct
* Use the smallest possible throttle opening you (and other traffic) can stand for acceleration, Not strictly cotrrect. A throttled engine is less efficient than a non-throttled engine. Big throttle opening at low revs is more efficient than smaller throttle openings at higher revs to give the same power. and as few revs as possible
* Cars use the least L/km the slower they are driven. Even more reason to stick to the speed limit. Again, not strictly correct. The most efficient will be the slowest the car can comfortably travel in top gear. The wind resistance only starts to have a big effect over about 60km/h
Most important factor and I can't believe nobody has mentioned it - avoid using brakes unless absolutely necessary. On the surface it sounds silly, but when you think about it, by the time you apply the brakes, you've already used too much fuel to get up to the speed that you need to use brakes. If you modify your driving style and think ahead, it's surprising how little you need to use the brakes. this means you're using far less power to get up to speeds where you need to apply brakes. No, it doesn't mean driving everywhere at 20km/h, either.
Also, if you think that knocking it into neutral to coast down hills is saving fuel, think again. Modern EFI systems shut off fuel altogether with 0 throttle and revs over a certain RPM (usually something llike 1800). If you coast in neutral, then the engine is being fed fuel just to keep it running, whereas if you're in gear, then the fuel system shuts down completely.
Follow some of these techniques and you can save a reasonable a mount of fuel. Just because you want to drive a Skyline doesn't mean you have to drive it like a dickhead all the time
new oxygen sensor - ask for one for an n14 sss pulsar (sr20) has the same plug as a 33 too so no cutting
get an ecutalk display too - i got one for my stag, plugs into the consult port and once you input the injector size it will do instant fuel consumption, read off every sensor the ecu has and do lost of things
www.ecutalk.com
Ride a bike. No, not because you drive the car less, so you lose weight and have less to push around. Of course, that's not going to have a huge effect.
Optimum speed is probably going to be 60-80km/h
If your weight is around 200-300kgs it might!~
www.ecutalk.com
Hmmmm i mite get that...so what exactly does the ecu does again?
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
