can anyone offer advice on where i should be looking to fix up my stuffup
i decided to give my r34 gtt a wash under the engine bay, on 3 occassions i started the motor and sh ran nice.
after shamming up the excess water, i moved to the snorkal, airbox and filter.
whilst this was off i started the engine to move the car a meter or so and wammm, the air and fuel mixture is off , rough idle, and crap performance.
i tried a ecu reset and now i have the traction light / engine light permenantly on ?????????
any help is worth something
https://www.sau.com.au/forums/topic/305242-r34-air-box-stuff-up/
Do/check all these things
make sure your air flow meter (which is a cylinder attached to the airbox and has mesh on both sides) is completely dry(let it sit in the sun for a bit?/hairdryer?), or that you haven't blown any dirt onto it's sensor as that would cause problems too...
Check that the plug/wires to it aswell to make sure they havent come loose..
Check you havent gotten some water in some cracks/all the pipes are well connected and sealed.
you said "i moved to the snorkal, airbox and filter" and then you started the car... did you have the airflow meter connected? if not, thats your issue as you car has no idea how much air it is sucking in...
also, when you did the ecu reset, was everything back in place and are you sure you did it properly? (im not sure how to do it as I have an aftermarket ecu, but just making sure)
gl with it.
Adam
hey thanks for that info,
the ecu reset was done again and this time around i got results my air flow meter sorted itself out. ( air/fuel mixtures are good )
my bad for now my TCS and SLIP light are on, wont go away. test drove her and the tractions is not working ?
is it a simply sensor or do i need to take it in to an auto electrician ?
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
