Hey guys,
I'm probably going to be pulling my head off again within the next few months, and would like to know, how do you test the valve stem seals properly when the head is off.
I read a post where Trent was saying that when they change them, they have to pressure test them (which you can't do when you leave the head on and do them with the special tool) so I'd like to know, how you do test them?
I want to pull the head to put an oil restrictor in, and also to change the valve springs (I know I can do it with head on, but I want to put the restrictor in too)
at the same time, I'd like to pressure test the valve stem seals in case they're shot...
https://www.sau.com.au/forums/topic/305260-testing-valve-stem-seals/
If you are not blowing exhaust smoke, your seals are fine.
Leaky inlet valve seals will suck oil under high manifold vacuum, mainly idle and backing off at high rpm.
Crook exhaust valve seals usually show up as smoke when you first start the engine up cold. Oil drains down the stems.
While the engine s running, especially under boost, there is usually enough exhaust back pressure to blow oil up OUT of the valve stems.
Unless you are seeing smoke, there is no problem to worry about.
I'm seeing LOTS of smoke...
At the moment the turbo is, and it all appears fine... That's the problem...
I'm seeing a SHITLOAD of smoke once I boost up for 2 - 3 seconds, and a shitload if I pump it back to 3rd gear at around 130 - 140KM/H with closed throttle.
these are the things you do while youve got the head off just to save yourself a headache later;
- service the head.. get it cleaned, get the valve guides checked and the valve stem seals replaced.
- machine all surfaces (head + exhaust side at least as well as the exhaust manifold - get the inlet manifold done if you wish, not as important though).
- get your valves checked for any bends
- clean/check lifters (submerge them in diesel/mineral oil the entire time theyre out)
- replace both front cam seals (same part number as the crank seal).
do these things as a minimum to save yourself a headache later on. well worth the time+money.
cold start the engine, hold rev at 2000RPM. If steam seals are gone you will notice some blue smoke. once the car warms up the smoke goes away.
Can't rev the engine whilst cold.
It's not perfectly tuned yet for cold starts etc, it will only idle.
The head is coming off, I've heard there is a proper way to pressure test them. I want to know how so I can. Heads being pulled no matter what soon, not because of the Valve Stem Seals.
  • 4 weeks later...
First you have to make sure your valves are sealing properly (all valves leak to some degree straight out of the factory)
Then you have to block of your inlet and do a leak down style test, if you know your valve only leaks 1%, but your getting a reading of say 5% then the other 4% must be going through the only other leak path, your valve stems.
But of course all this means nothing unless you have the factory specs to compare too.
I guess different work shops could have different ways of testing this, best to just ring around and see what they say.
MBS you said "I'm seeing a SHITLOAD of smoke once I boost up for 2 - 3 seconds, and a shitload if I pump it back to 3rd gear at around 130 - 140KM/H with closed throttle."
Is this constantly or only at start up? if its a dodgy valve stem seal after start up all the smoke is burnt away because it can only burn off the oil that could seep through while the car was off, unless you have a massive leak path here but thats rare.
It sounds more like a turbo seal possibly?
Also the smoke, is it whitish smoke? or a darker bluish colour?
It's a very whitish smoke.
And no, nothing at all at startup or idling around. Only when I'm giving the motor a bit of a work out after a few seconds.
Then it pumps a whole heap of smoke, take it easy on it, let it clear up, give it another hit and it goes again.
I had the turbo apart the other day, but I have no idea what I'm looking for with spotting a dodgy seal (When I saw apart, I mean I have the VBand un done and the rear housing off)
Are you running a restrictor on the turbo oil feed?
Bush bearing, so I was told not too... But I'm going to grab an oil pressure regulator (as have been discussed in another thread where someone runs an actual pressure regulator) and fit that to see if it stops.
My problem is, I'm at the point for a new bottom end to go in now... So I have to decide how I want to attack it to set the car up for track work... High Comp N/A that revs its guts out, or buy a whole nwe turbo/mani setup and stick with the bottom ends how I have been...
PCV is hooked up and working properly.
Coolant doesn't move. I've been told by numerous people it's oil. When it does any one standing around smells burning oil.
It's blue but not super blue like when a magna/excel takes off with stuffed rings.
  • 3 years later...
reopening closed thread. i did a cold compression test my results were within 120 -128 or so across the board. Seems like the rings are fine. I also have smoke on deceleration or when i give it gas it puffs for a bit. MBS did you find the cause to the problem. Willling to try and change them without removing the head aswell for the added costs of machining it and getting new gasket.
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
    • That's just a gauge, with a certain amount of electronic damping, and no-one cares if it is timely-accurate. I'd hesitate to use it for an ECU MAP input without knowing that it was a nice signal. Responsive but smooth. Not laggy. Not lumpy.
    • Took the dirty BMW to an actual drag meet so I could do a legit full pass on a sticky enough track and had a quiet goal to try and beat my PB in the old R33 GTS25t The time to beat:  R33 on stock RB25, Internal gate GT3076R on stock manifold tuned to about 17psi on BP98 and running on drag tyres: F20 M135i with intake, dump pipe and MHD OTS Stage 1 tune on street tyres - didn't even drop the tyre pressure: Kinda similar, and kinda way different
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
