describe what happens please
does the inj/ign etc all show zero's ?
when you do DATA INIT, choose Yes (non default item) then press NEXT and then reboot the car
does it retain the previous settings?
i could post up default BNR32 maps, but it would by far easier to fix the root cause
if it wont DATA INIT, then its likely it wont save other changes too
so let's clarify and fix that up first - so as above, try DATA INIT the way listed above
The unit is used. the inj/ing settings do not show zeros. It retains what it was even when shut down and the battery is pulled and residual electricity is drained from the system. Changes I have made prior to the DATA INIT are retained.
when i DATA INIT and reboot the car, the settings are retained. Although after I did the 30 min idle it seems to idle better.
Thank for your help or at least trying.
this is a known issue, its covered in the PFC FAQ
view it from my signature and then look for "ECCS"
there is a known relay issue, and when the issue occurs, changes in the PFC tune are not saved at power off
which also explains why the DATA INIT doesn't clear, read it, and it tells you the correct fix
when you key off, the PFC needs an additional 1-2 seconds to write any run-time changes to NVRAM
if the install is shagged or the car isnt wired correctly, the PFC isnt given the extra 1-2 seconds required at key off
the end result is, at key off, the PFC doesnt get time to commit changes to NVRAM, so it results in a Read-only PFC or a "unsavable PFC" like what you are seeing
Thanks Paul. I had read your FAQ but didn't realize that the ignition needed to be cycled after the DATA INIT. I'll give it a try and keep the ignition off for at least a few seconds.
  • 2 months later...
Sorry to bring this back from death, but a friend's evo VII is having this issue. Both Ign/Inj maps are filled up with zero's and any change i make gets errased as soon as i press the PREV button.
I only have the commander to tune.
How can i fix this???
THanks a lot in advance guys.
locked for sure.
yep as the others have said 0's on the hand controller for the maps is a locked powerfc tune.
find a local tuner who has apexi fc commander pro or datalogit and unlock it (simple tick box) and away you go.
i'll probably get from a friend a dattalogit box to use it with a laptop. But, how the heck do i unlock it? Is it a simple feature?
thanks a lot guys for your answeres.
yep
it's just a tickbox, no magic, no password
but sure to note, there are some things that are not restored when a tune is unlocked
be careful if this car has injectors that are non-std, and other key non std items such as AFM or map sensor
datalogit has some bugs where it mangles up the values sometimes when a tune is unlocked
i dont know why it does it, it just does its a bug with datalogit.
yep
Thanks a lot paul. I'll post up as soo as i try this out.
I really like the power FC but i also really hate it to have this kind of problems.
I'm experiencing a problem now with a MY00 WRX that doesn't save when the key is off using the commander. It's not an engine swap, everything is stock (electrical) but i'm having this issue.
Once again, thanks a lot for the support mate.
Cheers.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 馃槵 I'll let you know how I get on if I still have use of my hands afterwards 馃槄
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
