describe what happens please
does the inj/ign etc all show zero's ?
when you do DATA INIT, choose Yes (non default item) then press NEXT and then reboot the car
does it retain the previous settings?
i could post up default BNR32 maps, but it would by far easier to fix the root cause
if it wont DATA INIT, then its likely it wont save other changes too
so let's clarify and fix that up first - so as above, try DATA INIT the way listed above
The unit is used. the inj/ing settings do not show zeros. It retains what it was even when shut down and the battery is pulled and residual electricity is drained from the system. Changes I have made prior to the DATA INIT are retained.
when i DATA INIT and reboot the car, the settings are retained. Although after I did the 30 min idle it seems to idle better.
Thank for your help or at least trying.
this is a known issue, its covered in the PFC FAQ
view it from my signature and then look for "ECCS"
there is a known relay issue, and when the issue occurs, changes in the PFC tune are not saved at power off
which also explains why the DATA INIT doesn't clear, read it, and it tells you the correct fix
when you key off, the PFC needs an additional 1-2 seconds to write any run-time changes to NVRAM
if the install is shagged or the car isnt wired correctly, the PFC isnt given the extra 1-2 seconds required at key off
the end result is, at key off, the PFC doesnt get time to commit changes to NVRAM, so it results in a Read-only PFC or a "unsavable PFC" like what you are seeing
Thanks Paul. I had read your FAQ but didn't realize that the ignition needed to be cycled after the DATA INIT. I'll give it a try and keep the ignition off for at least a few seconds.
  • 2 months later...
Sorry to bring this back from death, but a friend's evo VII is having this issue. Both Ign/Inj maps are filled up with zero's and any change i make gets errased as soon as i press the PREV button.
I only have the commander to tune.
How can i fix this???
THanks a lot in advance guys.
locked for sure.
yep as the others have said 0's on the hand controller for the maps is a locked powerfc tune.
find a local tuner who has apexi fc commander pro or datalogit and unlock it (simple tick box) and away you go.
i'll probably get from a friend a dattalogit box to use it with a laptop. But, how the heck do i unlock it? Is it a simple feature?
thanks a lot guys for your answeres.
yep
it's just a tickbox, no magic, no password
but sure to note, there are some things that are not restored when a tune is unlocked
be careful if this car has injectors that are non-std, and other key non std items such as AFM or map sensor
datalogit has some bugs where it mangles up the values sometimes when a tune is unlocked
i dont know why it does it, it just does its a bug with datalogit.
yep
Thanks a lot paul. I'll post up as soo as i try this out.
I really like the power FC but i also really hate it to have this kind of problems.
I'm experiencing a problem now with a MY00 WRX that doesn't save when the key is off using the commander. It's not an engine swap, everything is stock (electrical) but i'm having this issue.
Once again, thanks a lot for the support mate.
Cheers.
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
