Well due to work and other commitments I dont have time or the energy to work on my 31 so its being stripped
All parts located in Devonport
$400 r43 gtt front brakes
$350 3 inch minld steel turbo back exhuast
$1200 rb25/rb30 hybrid with greddy copy plenum and loom
$400 brand new only dummy fitted to car t3t4 and stanless steel manifold with braced runners and used 38mm waste gate
$400 suspention arms with new nolithain bushes
$150 front sturts with white line springs and kyb shocks
$50 hot plates
$80 044 copy and 1ltr surge tank
$100 r31 coupe steering rack
$300 bucket seats mounted on r31 bases
$350 timex boost, oil pressure, air/fuel and temp gauges with remote
$300 timex tacho and speedo in one gauge
$50 good condition silo steering wheel
$400 16x8 +25 speedy rims with 2 good 225/50 r16 and to bald. one has gutter rub
$350 s3 front bumper with lip and vent in primer
$100 rb30e
All so have a few power steering pumps and altinators off rb30s
Thats just off the top of my head. I will up date as I work more out
https://www.sau.com.au/forums/topic/305371-wrecking-s2-r31-silo-with-rb30det/
Yeah its a pitty to have to do this but with work and other commitments I don't have time to work on it and my gf is about ready to get her licence so I need another car so the 31 has to go
pretty f**king soft red. oh and them seats where only $280 brand new rip off prick hahaha
Shell is also for sale. Price deppends on what parts are still in it. registered until the 08/02/2010 then has the 90 day to re register it
$50 1:1 fuel reg (cant rember brand but its from repco (not monza tho))
Edited by lawler
$50 hot plates
$100 rb30e
Hey mate would you do the seat for 250???
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
