Does anyone know a place that can test coil packs to make sure they are working properly!!!!
I am trying to rule one thing out at a time at the moment to find what is wrong with my car!!!
connect an earth lead and a positive to the coilpack top, then put the live bit of the coilpack on your tongue
it works, honest! >:(
(If it works with a 9 volt battery.....)
-D
have you looked for the error codes on the computer first ?, checked the grounds and plugs for corrosion, pretty common?
From what I have read around the place bench testing them isn't worth it.
If they are only charging $50 to do them they aren't testing them under load or at working temperatures. My guess is it's just a resistance check which can't rule them out as a problem, only at times confirm they are a problem.
Swapping them out is by far the cheapest and most definative way. Even if you can only get 1 known working one it doesn't take long to swap it through the 6 different positions. Once you have the coil cover off you can squeeze them in and out without having to undo anything else. All up it should take 2 hours max- that's if the last one you test is the one that's gone. I recon I could do all 6 in my stagea in under 1 hour
Also, if you cut off the lip at the back of the coil cover you should be able to get it in and out without removing the crossover pipe making future work easier.
Edit: not sure if you can get then in and out as easily on a R34, I've only done it on an R33 S2
Edited by Race__24
Just FYI there is a place that does this & last I knew, they did it for less than $50.... although it may cost that much by now.
The place is called Petro-Ject, located in Stepney (Ph: 81321622).
They will do testing on individual coil packs & heat them up to full operating temperatures & under high load. The guy that does it all has being doing the same kind of work for something like 12 years now & knows his stuff.
And just let them know that Jared sent you :D
Edited by J_Red33
thank guys, i have an intermittent missfire and no one seems to be able to rule anything out as there are no error codes coming up.
i have split fires already and they have done less than 5000kms in 18 months, so if it s them i wiil be pi**ed.
Would almost have to be a defective coil pack after only 5000kms for them to be the issue. What boost & spark plugs & gaps are you running?
Do you have the original coil packs? I'd suggest you'd try these first if they worked ok when you removed them.
The car spent 6 weeks in a mechanics trying to sort it out and all they came up with is that one of the ciol packs is slightly faulty as no error codes came up.
Just want to try and sort something as it is detracting from driving the car and my enjoyment.
Boost is only 10 psi and a .8 gap has been set with a fresh set of plugs as done by my mechanic.
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
