Hey
I broke a piece of this part but just interested to know what it is and what it does
I think it may be from the heater hose not sure.
cheers
http://www.nissansilvia.com/forums/index.p...howtopic=426434
hard to see in your photo,but it is a heater control valve of some sort . when you move the heater control inside it should open up to let hot water into the heater core to warm you up ? or stop the flow to cool you down.
wow
thats an old style heater valve - havent seen r33's running one of these before though.
think some info regarding your car and motor would make it easier
Was going to say the same thing, it doesnt look anything like what was in my 33
Hey sorry Guys
Its an R33 Gtst 94. Sure does open and shut.So is there something different to replace it with or should i stick with the same one.
Nice quick Response Thanks
Aaron
what opens and closes it? what is on the other end of that cable?
r33s run a climate control unit that uses the doors in the heater box to control temps - find it strange that you would block the heater line like a early 80's car does
Even climate control cars use a heater tap to control flow to the heater core. The climate control cars usually just have it mounted directly to the heater core itself.
Looks like a cable operated heater tap which would be controlled via a slide control inside the car.
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
