I was quite happy with 210.3 kw at the rear wheel on 1.05 Bar. But looking at the graph and comparing with other SAU results. I notice that my boost kick in at 95 KPH, while other people start at 60-70 KPH??? Also is it normal that the turbo kick in at 3500 rpm??? Thanks.
Mod:
FMIC
Apexi power FC
Apexi AVC-R
standard turbo
3 inch exhaust (straight to the turbo)
https://www.sau.com.au/forums/topic/30546-dyno-result/
wasnt first if you hit 95 k's.
As far as power goes it makes no difference which gear its in, that would only make a difference to the torque reading, which has to be compensated for by keying in the ratio between engine rpm and TOTAL ratios. (gearbox and final drive)
https://www.sau.com.au/forums/topic/30546-dyno-result/#findComment-619252
