as ive posted so many topics in the last few days some of u may know i jus got my R34 converted to a manual since i got it back nothing but litle problems..
my newest problem is the check engine light will come on and the car's exhaus note will sound exactly like a wrx (like the putting and stuff like that) and the car starts to shake in low revs feels as if its gonne stall on me... annnd i can hav my foot flat to floor in any gear and it will jus go nowhere like i mean struggling to hit 50klms in built up areas...
it slips in and out of this mode but the engine light never goes off but sometimes it will jus randomly go back to normal sounding (the exhaust note) and suddenly my power will be all back.. then the exhaust will start putting and sounding like a classic rex and it will run like crap again :D
could it be because i still have the auto ecu running and never hooked up the manual ecu?? or does it just need a tune or in anyones opinion/experience is it something else??
cheers
https://www.sau.com.au/forums/topic/305465-car-running-like-sheeet/
I have had a similar problem with my car.
It is either one of 2 things.
If the car drives along fine and then jerks along suddenly and refuses to rev over 2000~rpm, your air flow meter (AFM) is playing up. Its probably best to find someone with the same AFM and test it in your car
If the car has a misfire depending on load/rpm, it is your coilpacks breaking down, replace them with splitfires and you will never have that issue again.
From my experience there is no difference between auto/manual ecu, The A/T light on your dash will be flashing because the shift ECU is not receiving a signal. Just remove the cluster and pull the light out if it annoys you.
cause its not just like doing it underload or anything it will just do it randomly and it wont jerk the only thing that happens is (if anyone has had xperience with varex exhausts) suddenly the note of the exhaust will change and tahts when i kno its gone into the "mode" so to speak.. and then i can rev out every gear to the max and it will struggle to get up to 50k's even.. jus goes nowhere..
but i noticed this arvo i tested a theory that it happens after the car has been going for say 10-15 mins so after it heats up and when u stop start alot.. at traffic lights etc..
and how come they just went without warning? like i got my car back from the shop after it being converted to a manual and it jus happened.. i never had any lights on or any problems with it before i took it to the shops?? do they just do that randomly go is it just conincidence that my first drive of her after getting it back from the shops has nothing to do with it they just went randomly?
sorry about all the questions.. this is my first skyline im going from commodores to skylines so i kno absolutley nothing :D
good work on going from commonwhores 2 skylines mate :D lol
the problem more than likely isnt there when the car is cold yeh??? thats because the coil packs will get tiny lil hairline fractures in them... n as the car warms up the heat makes those cracks get bigger till the spark n all that missfires causing the car 2 sound like shit... if ur car has got bout 60 - 70 thousand k on it n its still got stock coils in it then they will be gone by now... engine light will go on and off n will get more frequent as the problem persists
not sure if the workshop touched them??? maybe dropped one by accident??? hints a crack in one
a temporary thing u can do is also tape them up tightly with good quality electrial tape
ahh yeah i got my car with 77XXX klms now has 92XXX klms so i spose they need changing... would this also be causing the car to feel as if its going to stall and shake about while im sitting in neutral/stopped??
and yeah it doesnt do it when its cold.. its after it heats up a bit.. thanks
id say coils for sure, sounds like all the same symptoms mine had before i changed them, all 6 of mine had blown, big black burn marks in the clear plastic resin casing
being a manual now, maybe your driving in higher rev ranges for longer putting more heat and stress on the coils which might have put them over the edge and it seems also very common from what ive read on here that once one coil goes, the rest go like dominos
ahh okay i see makes sense..
would this also cause my car to sometimes be hard to start? like i'd go to start it and it would jus kick over then clonk out then i'd hav to start it again and it would get really low revs and almost stall then the revs will all of a sudden pick up and she'll be fine??
deffinately, mines was often hard to start when id try pulling over to restart the car and clear the ECU of the error code, felt like it was flooding itself
i replaced mine with the just jap ones (the red ones if its a NEO motor like mine) they are even made in the same building in tiawan as split fires - according to the distributors, so far she goes great
okay cool thanks everyone... has really put alot of stress off my mind haha
how much is too much for a set of splitfires? i see them on ebay for $595 (+postage obviously) then i ask my mechanic who specializes in imports and skylines to be exact and he said around $700? are the ones off ebay the real deal??
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
