hi i have a r32 gtr and for some reason it keeps putting it self into rwd at anytime. the light will come on in the dash and stay on till completely turn it off and then most of the time the light justs comes striaght back on.
Does anyone what is f**ked or is it the cars way of saying do a skid ?
https://www.sau.com.au/forums/topic/305474-r32-gtr-4wd/
Could be a number of things.
The reservoir in the RHR quarter, is it full?
What size tyres are you running front and rear?
Have you got a mix of new and old tyres?
Could be a a sensor gone.
Have you got a copy of the workshop manual? there are some good trouble shooting steps in there.
Feel free to arrange a time to head over to Burnie if you want someone to have a look for you.
Always happy to meet another GTR owner and help out if possible.
https://www.sau.com.au/forums/topic/305474-r32-gtr-4wd/#findComment-5054761
The tyres are 235/45r17 all round and are the same the car was running for about 4 months befor (stephen corrected me if Im wrong)
My first thought was wheel speed sensor as well but its not throwing the abs light
as for reservoir Ill lol if thats all it is due to the facted that he should be smart enough to have topped that up when he bleed it. but it might not be bleed properly
Edited by lawler
https://www.sau.com.au/forums/topic/305474-r32-gtr-4wd/#findComment-5055090
attessa is very sensitive to earth, and voltage. My car pulled the abs wires into the compresser, which kept blowing the a/c fuse, and also made the 4wd fail. I've heard of people having earthing problems that cause it to fail too.
also when it fails, look at the attessa ecu under the rear parsel shelf, and count the number of led flashes.
Edited by sav man
https://www.sau.com.au/forums/topic/305474-r32-gtr-4wd/#findComment-5055356
When was it bled and does this coincide with the warning light issue???
Its easy enough to bleed, if you know what your doing.
If you dont, then its real easy to get it all wrong as well.
Same way its been bleed the same the other 3 times the gearbox has been out. tho the car has had the whole motor out and has only just got going again. from what he was telling me to day its intermittent and if you stop and turn the car off its fine for a bit then it will throw the light and be in rwd again
https://www.sau.com.au/forums/topic/305474-r32-gtr-4wd/#findComment-5055372
thanks for the help. think i have fixed it now. i bleed it again and cleaned all the abs sensors and been driving around all day and it hasn't done it again plus the 4wd seems to kick in quicker
https://www.sau.com.au/forums/topic/305474-r32-gtr-4wd/#findComment-5055391
Edited by 32gtrsteve
https://www.sau.com.au/forums/topic/305474-r32-gtr-4wd/#findComment-5059170
started doing it again. are you busy next week or sometime to have a look at it cause i dont konw what to try
https://www.sau.com.au/forums/topic/305474-r32-gtr-4wd/#findComment-5059177
Should be free most night next week after about 6pm.
Dont think I have anything planned at this stage for Sunday either... :s
Not sure on that one though.
Shoot us through a PM with your mobile number and we will tee something up.
https://www.sau.com.au/forums/topic/305474-r32-gtr-4wd/#findComment-5060051
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
