Hi Guys/Gals
Ok so ill start from the start.
Took my car in to get the following mods tuned.
t04e - plain bush bearing (I KNOW) (wastegate port has be honned out)
Aftermarket low mount manifold
Bosch 040
SAFC
blocked bov (yes stalls sometimes- so there was no fabrication to the intake pipe)
3inch intake pipe
catch can (yes hooked up correctly - so there was no fabrication to the intake pipe)
3 1/2 inch exhaust
Apexi Pod
$22 ebay boost controller
Was hoping to see around 200-220 kw atw (with my stock ecu and average turbo)
When my tuner did a few base runs, we saw the boost spike to 14psi and the ecu chucking a mental, even losing a 100 hp through the midrange the car still made a top of 269hp atw running rich.. As we were searching for the problem for the spike saw and felt the actuator rod not opening the wastegate fully, once i adjusted the tension on the actuator rod the car was no longer spiking but would hit 11 psi and fall off to around 6psi by redline which was only making around 230hp. we came to the conclusion that it was the crappy dual port 4 psi actuator. so he tuned the car quickly with what we had to work with, took some fuel out since it was still running mega rich.
next week i shot down to MTQ and bought a garret 8psi actuator, put it on and went for a quick run around the block before the tune, from what i saw on the boost gauge it seemed to be holding .6 bar fine. we put it on the rollers and did a base run, boost was around 10-11 psi but tapered off to 7 psi, checked the tension on the rod and there was enough spring tension to hold the wastegate shut also the car was down 10kw from what it was a week ago. and lost quite abit of power in the mid range also was running a little leaner then a week ago, we tried winding the boost controller right up, it only added 1 psi and still lost boost to 7. We the turned the boost controller completely opposite way it made a constant 4psi right across the rev range?? souldnt it be 8psi since thats what the actuator is? we also tried a GFB controller on it as well with same results. We then checked the part number stamped on the actuator and it is indeed a 8psi. No matter what we tried the boost was leaking off..
Now could this be a restriction in the exhaust? (was thinking of droping the exhaust from dump and see how it runs, then maybe from exhaust housing if it made no difference from there) its a JJR Turbo back exhaust with a split down pipe and "high flow cat"(not actually to sure how high flow lol)
What are some of your idea's? bellmouth? i cant see why it could spike and build to 14psi but now it cant even hold 11psi?
sorry for my life story just wanted to try and explain fully to you guys.
Thanks Richard
https://www.sau.com.au/forums/topic/305486-rb25det-boost-tappering-off/
It could simply be the manual boost controller... I think they don't hold boost well in the upper rev range. Have a search here on SAU, it's well documented.
You kind of have to weigh up the pros and cons - $30 for a controller that holds pretty well, or $500 for an EBC.
I'm happy with the turbotech manual controller hahaha.
And if I didn't understand the problem properly, I apologise
Say what? Any links to where such a statement is well documented?
I've never read such posts...
Properly setup, boost control, will work fine regardless of if it has flashy lights and buttons or a screw top.
I've never used anything other than a bleed valve. Made over 370rwkw, 24psi @ 8000rpm.
So it comes down to installation 9 times outta 10.
nismoid i know you know quite abit what are your idea's or solution? ive checked the vac lines, my controller comes off the cooler pipe to the boost controller then to the actuator. the vac's are brand new and the actuator is brand new, tension seems correct. I did also mention we tried a gfb controller on it as well with the exact same result. hmm
drop the exhaust first, see what happens.
also when the internal gate was ported, was a new end cap used, larger one so that air does not go past?
Why was the rear ported anyway? They flow enough for the turbo they are.
yer when i got the turbo the port was only at 20mm, i was told this causes spiking on alot of these shit turbos so i got my fitter and turner at work to port it out to around 29mm, hyper-gear then built me a rear flange with a 33-34mm wastegate flap, im almost 100% sure that it overlaps the port by atleast 1mm all round, yea the exhaust will be the first thing to drop tommorow when im back at work with access to a hoist.
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
