guys just bought a turboX boost controller,hooked it up and have played with it for hours!!! and the loweset i can get it going it is 13 psi,with spikes up to a 15! car is a r32 gtst full 3 inch, high flow cat , pod,bov,why is it so high and is this safe?
cheers
have you got it setup right ?:S
cause we use turbosmart bleedvalve an we can run what ever boost we want ?
(r33 gtst)
spikes on a bleedvalves are common. their not to good for holding boost either.
have you got a pic of how its setup ?
Here is a pic (attached) of how it is setup. From the picture you can see that the bottom hose goes to the wastegate whilst the hose on the left goes down and to the turbo. It was setup as the instructions said and is set up the same as on my brother's 180. The instructions say to never let the fine adjusting screw more then 2 turns from fully closed otherwise lag will occur. If I set it to 2 or more turns then it spikes past 15psi. So it is now set at less then 2 turns. The coarse adjusting valve is also set as low as it can go. I'm not real sure what the problem is only thing I can think of is that the hoses have some kind of problem ?
u hook 1 to the wastegate line on the turbo and the other to a pressure line on the intake (cooler pipe is easiest), thats how it reads the 2 different pressures
Thats right :thumbsup:
it should look somthing like this. one goes to the actuator and the other hose coming off the bleedvalve should go to the intercooler pipe :(
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
