So my car just failed it's MOT test, the upper control arm bushes are gone. I guess that explains why one side was running -4 degrees camber and the other side +1 1/2.
So I need to fix this. I was wondering how to go about it.
So far I've found the following, assuming that R32 GTR bits will fit the suspension on my 4WD Ceffy
R32 GTST/GTR front camber arms
Reasonably-ish priced, but maybe too much NVH for a daily driver since they replace the bushes withbearings.
Whiteline camber adj kit, upper c/arm
Seems like the best option as I get polybushes so should be nicer to drive, and I get a bit of adjustment just in case it's needed. The downside is it's extortionately expensive and I'd have to keep greasing my nipples afterwards
Polyeurethane bushes
Should be fairly cheap and not too bad for NVH. The downside is that no bugger sells Upper wishbone polybushes for the R32 it seems.
Any suggestions?
Edited by Lum
  • 1 month later...
Over here on Adelaide, OZ, We have suspension places that do wheel allignments, shocks and replace all types of bushes standard and aftermarket.
Whiteline is a great option slightly expensive yes but you will find the poly not adjustments to nearly be the same price, expect few hundred installed but the car will drive so much better.
Good luck
Also here in australia we've got a manufacturer of quite a few polyurethane bushes, some even come as full assemblies with nickel-plated steel etc.
they have a part number for the R32 GT-R, front upper inner and outer control arm bushes, alignment adjustable, 45488.
Nolethane bushes are f**king awesome. www.nolethane.com.au
Nolethane are good, and they list a complete kit for front and rear for A31 Cefiro RWD, which is what I've got.
For the AWD models, just order R32 GTS4 parts, and any bushes immediately on the front knuckle assembly needs to be S13 (such as the bush between the knuckle and lower control arm, and the bush for the steering arm end).
Ended up getting the whiteline ones as I didn't want the NVH of the solid arms. The car passed it's inspection so I'm good for another 12 months.
that nolethane site doesn't seem to exist, or it's down at the moment, but will check them out when funds are looking a bit better.
edit: it's www.nolathane.com.au
Edited by Lum
You try catering for all the mechanics within a 500km radius (excluding metro phags of course).
I've just got a lot on my plate right now okay.. *starts twitching and crying*
  • 1 month later...
Should probably update this.
Went with the Whiteline R32 GTR ones since they were in stock and available next day at Demon Tweeks, bloody expensive for what they are but I can't fault their performance.
Got them fitted, passed the MOT, got an alignment. Guy at the alignment shop hadn't seen anything like it (the Ceffy, or the whiteline bushes), spent 10 minutes swearing at the bushes until he figured out how they worked then praised how easy they were to adjust :D
Out for a test drive, he throws it into a corner "bloody hell", he exclaims. "what?", "This is really nice. I thought it was going to drive like a barge and be all wallowey" *proceeds to throw it into the next corner at about double the speed limit for the road* "I think it's aligned right".
Car is driving better than ever now. Just had the sill fixed where some muppet in Japan has put a jack through it, now just got to find out why my front suspension has started creaking. Hopefully just needs more grease now the whiteline bushes have settled in.
    • But, do I have to? 😬
    • While doing my tailgate struts I found some rust. Also replaced my bonnet struts. Such a cool satisfaction with that job.
    • So I removed as much as I could from both sides. The shop vac did a great job of clearing 99% of it. I got it all as clean as I could and then absolutely drenched the whole lot in the rust converter. Tonight or tomorrow I'll hammer it again. The cavity must be close to 400mm in length and surprisingly I was able to get it right to the back.  I'll quickly reassemble and then pretend I never saw it. I'll post pics (for me to ignore later) soon.
    • Yea she is a hoot to drive
    • I have always resisted the urge to go silly. 8" wide wheels and street friendly spring rates? Check. (Let's not talk about the steadily increasing spread of spherical joints across my suspension!!) Stock turbo, run at 12 psi? Check. Lasted for~?10 years before it died. Highflow put on rather than seizing the opportunity to go G45. You don't need 300 rwkW, let alone the more massive numbers that seem to be essential these days, to have a car that is already way too powerful and fast for a streeter. ~250rwkW is fine. I've never exceeded 200, although I will sneak up above it if and when I manage to get my finger out and do what needs to be done to use the highflow's capacity. You don't need $10k worth of CF bits glued onto the outside. You don't need razor sharp ankle cutting front splitters. You don't need the car to be 2" off the ground. You don't need flawless paint, mirror finished wheels, brand new indicator lenses, etc etc. All these things just make the car impractical and will cause you pain when they get damaged, which is inevitable for a street car. A few nice additions are good. Good seats are good. A nice stereo is good. A/C is good! (46° on the road yesterday and my A/C is degassed again. Was moderately traumatic driving home!) The main reason I stick with a mildly modified old Skyline is that I have had it for >25 years, the mods are the rolling result of 25 years of things dying and being upgraded opportunistically, coupled with a few "just 'coz" ones. And I hate almost all modern cars. If I was a young buck starting out now.... I wouldn't bother. Cars have a few years left where there is any possibility of interest or fun. Thereafter there will be no such thing allowed or possible. Any time, money and effort spent now on a project would just be a waste.
