  • Replies 58
just updated my firefox to latest, did a full clear of cache etc
still can only use quick reply not full reply
windows7x64 if that helps
Nope I still can't use 3.63 to post in here. When I try I don't get any cursor in the reply field.
Nismoid - Na mate it doesn't show up and it doesn't type. Only way I got to post a new thread was to use the trick that Lum did by inserting centered text and typing in that box so at least there is a sort of work around in place :)
Still nothing on the IPB forums about a possible permanent fix??
Well it doesn't affect everyone :)
I don't have a "cursor", but soon as i click into the text area it appears so i don't see that as a big problem...
The issue some of you have is only for a small group of people so definately a compatability issue with FF & IPB (as im perfectly fine and on the latest builds) :)
Nothing has improved for me, I have another bug now as well, all the reply and quote buttons are no longer pictures, they are just text, a lot of the boxes and highlighting appears to be missing as well.
Really starting to drive me mad, what have the designers of IP Board said about this? Surely we can't be the only website that is having issues.
edit: Actually editing and quoting has magically started working again.
I don't get the cursor appearing randomly when I create a new thread however.
Edited by Rolls
Also what the f**k is this flood control bullshit, this along with the post editing being disallowed are the most retarded features ever, no other website has them and if they do they have reasonable ranges. Eg you can't post within 5 seconds, not 30 and editing is only disabled in the trading forums.
christian, i also had this issue and i know its fixed but it looks like you broke some other images too full editor/addreply and quick reply. only noticed in the dark skin though. see pics. also i just realised that if you hit edit, there is no option for quick edit. straight to full edit
separate issues to the forum move mate. they've been in place for a while now. once donations are up and running again, you lose the flood control upon donating
Yeah the donations WILL remove the posting/restriction issues.
Currently (ill be brief, ive gone into it plenty of times in more details)... dodgy traders are at an all time low.
I've had i think now 5 complaints in the last 12 months. To me, that is a win regardless of how "annoying" the forums are.
We are restricted by IPB (the old version), and the upgrade to SAU 3.0 will bring with it a lot of enhancements we want to get done.
So rather than abuse and swear at us, when you know the reasons, a little bit of acceptance for the greater good?
If you knew how many hours a week Nick & I spent dealing with bad traders 18+ months ago... it would frighten you.
i'm running firefox 3.59 and i'm missing all the bold, insert image, quote, etc icons like in the pics basti posted. just happened today. just tried cleared firefox cache and didn't fix anything. just changed to light skin and they are all there. changed back to dark skin and they still broken
Yep, will sort that tonight,
I found an interesting "quirk" at the top of the fourms there is a "fourm options" button, only works in 'normal' skin not 'dark' nothing major, just making a note cuz it took me a while to work out where I was going wrong :P
Hmm, odd. Thanks for pointing it out.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
