RB25DET Neo Vs RB25/30
47 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey Guys,
My 2002 R34 GTT shoud be arriving in a couple of weeks and just planning my build so I need some advice.
I'm contemplating either one of two options:
Option 1: RB25/30 Rebuilt + TO4Z = 400+rw/kw
Option 2: RB25DET Rebuilt + GT3540 = 350+rw/kw
However I have a couple of issues to address:
1. It wil be a drive in/drive out build therefore labour will be a killer (RB25/30 will be very fiddly to fit)
2. Will I have trouble engineering the car with the RB25/30?
I spoke to Jim from DART and he recommended to build the RB25 as its a street car and that I will be very happy with 350rw/kw and not have the hassles of RTA compliance issues. However, CRD recmmended the RB25/30 as there wont be much difference in the build cost however as a dollar value, will net much more power and torque than the RB25.
I am so confused please advise!
Regards,
Sarkis
https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/
  • Replies 45
RB25FTW :D
There isnt much of a price difference when building a 25 or a 25/30.
The only fiddly part about the 25/30 is drilling a hole in the block and plumbing up the VCT. If you have done it before its not hard at all.
It all comes down to preference in the end.
Anyone can make tough 30s, tough RB25s are the new black :)
Ill take you for a spin after my car gets tuned.
RB25FTW :)
Anyone can make tough 30s, tough RB25s are the new black ;)
Hahah I promise Dave, your car is the ONLY thing making me consider an RB25DET build ;) Can wait to see yours after the tune!
However being a daily driver it wont be tuned on E85 :D so im not expecting more power than yours. However the RB25/30 will make big power on pump fuel.
If you had a T04Z on both engines they will make roughly the same power.
Its the way and where that power is made that is the key.
For a very responsive 25/30 i would consider the new GT3788.
Yea thats what Jim from DART said... That they will make the same top end if setup right however the RB25 will need more boost and the RB25/30 will be less lag with more torque.
Dave what power would should a RB25DET + GT35R make on PULP?
For a street car... I'd be going the 25/30 but actually probably looking at the 3540 or a touch smaller.
On the street, for a very tractable car, you want and need response.
Also, in the comparison of a 25DET VS 25/30DET, think about the fact, they may both make 400KW, but the 25/30 will do it roughly 1000RPM earlier... Meaning there is way more torque being put down, which is what makes you go fast.
lol 400kw street car.....
save yourself some dollars and just get a hiflow and shoot for 250kw will be more fun than a 400kw lag/no traction monster on the street.
but if you got $$ to burn rb30 for sure!
I was going to say a similar thing. 400rwkw in a RWD street car is I’m afraid, nonsense.
However I wouldn’t say 250rwkw :D
QRI05E - have you even seen how pointless 350rwkw+ is in a RWD car on the street???
I was driving around with a RB25/370rwkw on the street for a while, utterly pointless.
You had to constantly be thinking about when it was going to break traction - as that is all that the car did. Would just turn tyres as opposed to moving anywhere.
The first 3 gears also serve no purpose so you have to be over 150km/h before you can even hope to have some use of the throttle without frying the tyres.
My advice - GT3076, make your 300-330rwkw, put it on a 25/30 like Al has done. A nice setup, responsive and most importantly, controllable & progressive.
Less in terms of power, is actually more in terms of how fast it will be.
And a NEO25/30 will be even nicer again, really nice low end.
One of the reasons i have a RB26, with around 300-330rwkw max - once it's done.
The 280-330rwkw power range is the best compromise between having solid amount of power to make you giggle as it will turn tyres if you want, while actually still being a solidly fast street car because it's controllable at the same time.
So what turbo am I looking at for 380+rw/kw?
TO4Z with a 0.81 Ex?
A GT35 will do 370-400rwkw on PULP on a decent motor.
A T04Z is 400-450rwkw on PULP, again with a decent build.
I run a "250RWKW" RB25/30DET... It turns the tyres at 130KM/H in 3rd...
No, it's not a nice power delivery, nothing below 3500RPM, full boost at like 4000 - 4500RPM... Turning tyres from 4000RPM onwards...
Power isn't the main thing to worry about (Power from a 25DET isn't really comparable to that of a 30DET as they make the same power, lower revs, more torque)
I believe a couple of the guys are running 25/30s with stock 25 turbos on them and are able to turn the tyres in 2nd/3rd with just a prod of the throttle too... The torque from a well setup 25/30 is just unbelievable...
What is your traction setup? (diff/tyres/suspension)
Even someone with a RB25 and a stock turbo can get their tyres to turn coming onto boost if they have a poor setup and only 190rwkw.
See it all too often unfortunately that people sped 10k on power, and only $1000 on tyres and some silly hard jap suspension.
I'm also assuming the OP will make a decent turbo choice, one that is progressive rather than older style 'light switch'.
Semi slicks (A048), on stock suspension (Squats down VERY well). (This is on the track too frying in 3rd after warming the tyres up)
The main killer, is as you said, the "Light switch" delivery. It is very much light switch, and I'd like to head down to something like a 3076. (Turbo is quite large and laggy... Won't really "come alive" till I'm pushing 24+ PSi, only on 14 atm)
Well that kinda answers your own issues doesn't it? :D
Non progressive power delivery, turbo not suited for the application (im assuming at least a 700hp by the sound of it), which is what i said initially would not work well anyway...
Maybe as Nismoid said, with a poor suspension/tyre setup.
My 32 has bulk traction and that's with -2deg camber on the back, rolling on boost in 2nd and 3rd wouldn't light up but a 3000rpm clutch drop in 2nd from standstill would light the hell up.
I'm hoping with the GT35R it lights up rolling on in 4th :)
bubba, you will do 3rd easy but i haven't had troubles with 4th gear so far even with some nitromethane additive in the WMI (good for 30-50hp apparently, seat of the pants dyno says it makes a noticeable power gain assuming the 50hp boost thats 490hp @ the rears)
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
