bubba Posted January 28, 2010 Share Posted January 28, 2010 Yay! Got any engine bay pics Titan? Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5058239 Share on other sites More sharing options...
cactus Posted January 29, 2010 Share Posted January 29, 2010 I used to run a built RB25 in my HQ (auto box) making 280ish rwkw @ 20psi. It was very fast once on boost (GT3082R) but it was still relatively laggy with this turbo. I then built a RB30 bottom end and matched it to the same turbo, the car made more power @ 18psi and 1000ish RPM earlier. It was the best decision I ever made and I absolutely regret wasting my money on building the original RB25. The 30 is just so much smoother and nicer to drive. So much power and torque down low and it just pulls and pulls and pulls. If I could do it all again, I would go straight to an RB30 bottom end... Especially on a street car when low RPM cruising is essential. I'm now running a GT3540 and it still makes boost earlier than the 25 with small turbo and its a billion times better to drive. Thats my experience Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5060074 Share on other sites More sharing options...
QRI05E Posted January 30, 2010 Author Share Posted January 30, 2010 (edited) How about all those Supras, RX7's and Big V8's running 800rw/hp with 9-10sec passes that are all RWD? I think it comes down to decent suspension, tyre setup and launch control. From what I have read, the RB25/30 will be a great street/drag combo however just waiting to take a drive in Dave's car to see how the new RB25 + turbo setup goes Edited January 30, 2010 by QRI05E Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5061560 Share on other sites More sharing options...
drift_dingo Posted January 30, 2010 Share Posted January 30, 2010 Hmmm I await your impressions QRI05E, I'm in the same boat as ya, got a r33 gtst s2 bone stock (engine wise) and looking for idea's xD. alas the age old debate, rb25 or rb30/25....plus being in nrth qld limits my engine builders down a bit. Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5061866 Share on other sites More sharing options...
TiTAN Posted February 1, 2010 Share Posted February 1, 2010 Nothing stopping you shipping the engine/bits down to them to get it built. Bubba, missed that post will pm you some. Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5064678 Share on other sites More sharing options...
drift_dingo Posted February 1, 2010 Share Posted February 1, 2010 any suggestions onto who does 'mail in' engines? I'm doing research ^^; Nothing stopping you shipping the engine/bits down to them to get it built.Bubba, missed that post will pm you some. Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5065720 Share on other sites More sharing options...
TiTAN Posted February 1, 2010 Share Posted February 1, 2010 rips will send you a prebuilt engine. most engine shops if you ask will more than likely allow do it. Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5066045 Share on other sites More sharing options...
bubba Posted February 2, 2010 Share Posted February 2, 2010 Bubba, missed that post will pm you some. Cheers Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5068391 Share on other sites More sharing options...
QRI05E Posted February 3, 2010 Author Share Posted February 3, 2010 Spoke to Adam my tuner today and here is what we have decided. Stock RB25DET Neo - High mount twin scroll manifold - Garrett GT35R with .82 rear - Bosch 040 - 800cc injectors - SARD FPR - FMIC - Greddy Plenum - Q45 Throttle - Full exhaust - Haltech E11v2 Should see easily 300rw/kw Drive around for a while... then when I need more power... RB25/30DET with the same setup should see 400rw/kw Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5069916 Share on other sites More sharing options...
TiTAN Posted February 4, 2010 Share Posted February 4, 2010 twin scroll manifold with non twin scroll rear housing on the turbo? i am not sure if a 040 will support 300-400kw, you may want to look into using a 044 instead. forget the sard fuel pressure reg waste of money, 800cc injectors will outflow a GT35R @ stock fuel pressure. Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5070662 Share on other sites More sharing options...
MBS206 Posted February 4, 2010 Share Posted February 4, 2010 twin scroll manifold with non twin scroll rear housing on the turbo?i am not sure if a 040 will support 300-400kw, you may want to look into using a 044 instead. forget the sard fuel pressure reg waste of money, 800cc injectors will outflow a GT35R @ stock fuel pressure. Agreed. That, and with that turbo, why not throw an RB30E in there, run less boost, make more torque and earlier, and have a much more streetable setup? Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5070753 Share on other sites More sharing options...
QRI05E Posted February 4, 2010 Author Share Posted February 4, 2010 I will be throwing in the RB25/30 in there eventually... just didnt see the point of ripping out a perfectly good engine. The reason for the GT35R is to that when I do decide to build the RB25/30 I wont need to update the turbo. Would a T04Z be overkill? Im thinking about the new Garrett GT3788R... Any ideas? Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5071270 Share on other sites More sharing options...
R31Nismoid Posted February 4, 2010 Share Posted February 4, 2010 What's the resoning behind changing the throttle body exactly? All it'll do is hard throttle control. Not like the factory unit doesn't flow enough, everyone else has made 380rwkw out of it easily enough. Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5071466 Share on other sites More sharing options...
QRI05E Posted February 4, 2010 Author Share Posted February 4, 2010 (edited) From what I have seen, all the 400kw+ RB's switch to a larger throttle but we'll see how we go. Will I run onto any issues with the RB25 Neo head on the RB30? I have read a few posts with people running into a few issues such as the bolting up a Greddy plenum with the factory thottle body. Edited February 4, 2010 by QRI05E Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5071662 Share on other sites More sharing options...
QRI05E Posted February 4, 2010 Author Share Posted February 4, 2010 (edited) What would a factory RB25DET + GT35R or GT3788R be like with supporing mods? Streetable? Edited February 4, 2010 by QRI05E Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5071663 Share on other sites More sharing options...
QRI05E Posted February 4, 2010 Author Share Posted February 4, 2010 (edited) EDIT: Double post Edited February 4, 2010 by QRI05E Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5071664 Share on other sites More sharing options...
R31Nismoid Posted February 6, 2010 Share Posted February 6, 2010 From what I have seen, all the 400kw+ RB's switch to a larger throttle but we'll see how we go. Where have you seen this exactly? Just because people change a part, does not mean it's a requirement or needed. Some people just get caught up in what they get fed. recent thread come up about this actually! http://www.skylinesaustralia.com/forums/La...dy-t291471.html Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5074316 Share on other sites More sharing options...
QRI05E Posted February 6, 2010 Author Share Posted February 6, 2010 R31Nismoid - Thanks for the info, like I said, i might just wait and see how we go. Anyone used a GT3788R on a RB25 yet? Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5074463 Share on other sites More sharing options...
MBS206 Posted February 6, 2010 Share Posted February 6, 2010 R31Nismoid - Thanks for the info, like I said, i might just wait and see how we go.Anyone used a GT3788R on a RB25 yet? If youwant streetable response, look at the GT3076 or the 3082. When that gets thrown on the RB25/30, you'll have an unreal combination that will NOT have to be revved, but will be able to when needed. Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5074660 Share on other sites More sharing options...
QRI05E Posted February 6, 2010 Author Share Posted February 6, 2010 I love the way the GT3076 sounds when it spools up... and have seen them make over 360rw/kw on an RB25DET Should I go IWG or EWG? Link to comment https://www.sau.com.au/forums/topic/305513-advice-needed-rb25det-neo-vs-rb2530/page/2/#findComment-5074754 Share on other sites More sharing options...
