Just a quick question, If u take off normally but then slowly boost it into the high revs 7 -8000rpm in 1st gear just to feel the boost but theres not enough road so then i put the clutch in quickly and let the engine wind down like its in nuetral, is that shocking the engine more then putting it into second gear straight away?
Summary: The revs go REALLY high in gear then then in mid or high boost take it out of gear, im just wondering if that bad for the engine?
https://www.sau.com.au/forums/topic/305531-what-stresses-the-engine-more/
meh its basically like reving ur engine while ur cars in neutral but ur using the gear to move the car..
i dont think ur doing damage.. but like any car sooner or later u will ware out something ... piston rings or something especially at 8000rpm...
personally i dont know why ur thrashing 1st gear to 8k rpm all the time ... ur gona blow something.
Also on that note.. i hope ur not killing 1st gear that much on our Victorian roads :D
Actually its more like 7000rpm thats the peak time of boost when i normally kick it into second, but sometimes you dont want to keep going.. so u just nuetral it. (sydney) :)
Please dont do this on the street, it makes baby jebbus cry and makes the police a bit upset to, do some track days and stuff and leave the hooning to the falcodoores.
from reading this post and a few of your others it seems you have no idea about how to drive a car, let alone a GTR.
i suggest you sell it before you hit a pole, seriously.
im just asking cause i havent been taking it out of the garage for awhile and went to warm it up around the block but theres not enough road and wanted to hit boost lol its not like i do it every time i drive... Battery ive been driving the car for 3 years now! asking whats stresses the engine more this or that makes not know how to drive ?? i bet i drive the car better then u !
Edited by GTRAAH
lol your not supposed to hit boost until the car is warmed up, let alone 1st gear 8000rpm journeys...
Why u flaming the bloke, hus just asking a question.
And Juz...... wtf are u doing here, you dont even have a car...... the BMX bike forums are just a google search away for ya..... go bother someone eles
Not warming i meant lubricating it haha I know your not meant tohit boost until its warmed i idled it for ahwhile before driving around the block.
ahahaha, the flamers in this thread are just as bad as the OP. no infact they are worse (except terry). h said he is only mildly boosting it up to high revs. not flooring it. 2 completely different things. also not really hooning other than making noise. and even in a 50km/h zone, he wouldn't be much over the speed limit in first.
as for whether its bad or not, it wouldn't be that bad. i'd say that flooring in and boosting hard up in first to 6000rpm would be worse than light boost to 7000rpm. and i think dipping the clutch would probably be better than using using the engine to slow you down from that speed as the less time you spend at higher revs the better. however you will slow down just as quick (or maybe even quicker) with it still in gear.
personally i'd be going to 2nd, then slowing down again rather than holding 1st or dumping neutral and freewheeling it to a stop without the driveline engaged.
or rev it out in a 100km zone to ensure you are within the speedlimits.
Um yeah right.
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
