boy oh boy... what to post... do i help... or do i flame??
first.. a question... why are you just taking the car around the block?? from experience... its because you dont have a licence at the moment and you are getting antzy..
to really feel the boost... its better in 2nd gear.. the gear ratios are better and your max speed will still only be around 120km/h.. which if your doing the above question.. wont really matter unless a kid steps out in front of you.. the sheer velocity of doing it in 1st is hard on the driveline.. and your top speed is only going to be 60-80, not really worth it if your going to be an idiot in a surburbian street.
and the answer is dont knock it back into neutral... at 8000rpm, its dumping in enough fuel and timing to support the load and pumping enough oil and water around to handle the conditions... then when you knock it back to neutral, that all dies off... the engine and turbos get incredibly hot due to the lean running conditions when its all shut off like that, all that heat has nowhere to transfer to as the water pump has returned back to idle speed and the head now has copius amounts of oil floating around and none in the sump. the turbos are still spinning at 70000rpm and the oil flow goes from lots... to not lots.. so the not lots of oil in going through the extremely hot and still spinning turbos is going to overheat and lose its lubrication and cooling properties, at worst possibly carbon up and clog or restrict the galleries in the turbos
another thing to take into consideration with the gear ratios of 1st gear is the engine braking... if you punch it in first then let the revs die down, its so abrupt that it throws you forward in the seat, it can nearly lock the back wheels just by stepping off the accelerator.. its not good for the clutch, gearbox, driveshaft, diffs... etc..
so your best bet... if you really must do it... is get it rolling in 1st, punch it in 2nd, clutch in and then change to 3rd or 4th to let it wind down by itself so that everything is in check.
im waiting for his next thread my engine just died what do you think happened lol
+1 for oh dear
aslong as he doesnt wrap it around a tree... there are always buyers for a gtr with a blown engine... i hope i see it on ebay for $5000.
Whats with the hate, his just asking a question, would you rather rev 2nd gear into 8000rpm instead of 1st? that would be more stupid if your driving around the block or anywhere besides the highway. Everyone redlines their cars every know and then, i do it often in my rx7 as their rev happy and it cleans out the rotary. I usually redline first gear to 8700rpm then shift into 4th going 60kmph, although sometimes i hit 70kmph in first. Also the shock would go into your engine mounts when you suddenly drop the gas causing the engine to move. You can absorb this shock with one of the engine torque something... if forgot the dam word for it lol but it basically absorbs the shock for the engine moving during acceleration and getting off gas.
Edited by Phuong
please enlighten us what makes u guys good drivers do u guys never give it the occasional squirt ? this is a serious question ! as i do not want to wrap it around a tree..... only had the car 11 days...
Basically what people are saying is if you keep redlining it in 1st you're going to break something. If I'm going to redline any gear it's usually 2nd, I'll be going to fast to redline it in 3rd (for the street) and boosting 2nd is my favourite anyway. :) Are you licensed to drive the car?
Edited by toddr33
How much thrashing can an RB take? I mean I see some people wringing their necks everyday.
Mine sees 5-6 grand daily. I mean I normally give it a couple of squirts to and from work basically, not bouncing it off the limiter all the way of course! :down: . 99% of the time it is just crusing at 2-3 grand of course.
Edited by Tony de Wonderful
rb20's can take a pizzling... limiter bounce well after the rings are shot and the detonation is going mental!
what makes you a good driver is learning the car.. knowing your car and how it reacts under given situations.. being able to feel what the tyres are doing on the road surface..
everyone on here will give their car a bit of a punch every now and then.. noone can or will deny that..
but there is a time and a place.. and if youve just got the car, that place is a skidpan and that time is with a professional instructor.
you need to push the car beyond its limits in a controlled environment so you know where they are and how it will react.
the reason new GTR drivers pound into trees is because over 20 years, the attessa system tends to get a little slow.. they are already slow reacting in the r32 when new..
so they punch it around a corner, and it steps out, so they counter steer it, and then the front wheels kick in and spit them off the side of the road into the nearest immovable object.
GTR drivelines can cop a pounding, 9k launches all day if its tight.. but the engines cant.. they are at the age where they are ready to go POP!
This forum is getting just as bad as the others. Why comment if your just going to bag him?!? Its pointless and to be honest most of you musnt have anything better to do with your time.. Either answer the question or dont bother saying anything at all.
I'd say shift to second and let it wind down. Harsh treatment for it clutching it at such high revs.
so long as you dont crash into me(probably not gona as im long way away) its his money, im trying not to insult people but in my opinion only people who are smart enough to understand cars should be allowed to drive them,there would only be about 5000 car drivers in the world if i had my way lol i realy do blame henry ford for allowing regular dumb joes to drive a weapon
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
