When I read the post heading I thought WHY WOULD ANYONE BOTHER? :looney:
But then 7 posts later, all was revealed :idea:
So I gotta ask, why didn't you put the T4 internals in the R25 turbo?
SK - I got the turbo for the cost of a bog stock, NA RB30 long motor (~$350 from memory). It had already been modified by the previous owner, who had it on a VL. Far, far cheaper than modifying my existing turbo.
Wouldn't the aerodynamics be a moot point, with both wheels having been replaced as part of the rebuild? Or am I missing something?
PS, I mentioned that it had T4 internals in the first post :rofl:
I would have removed the T4 internals from the VL turbo and stuck them in the RB25 turbo. All you would have had to do was machine the RB25 turbine cover. Coupla hundred bucks with new seals and gaskets. Maybe worthwhile thinking about. :rofl:
so how efficient is the stock R33 turbo?
I have been wondering myself. Some say 12psi and others say 15psi.
Around here people are craving these ball bearing turbos and I could sell it for $350-400. Sell that and just spend another $200-150 on top of that profit and get a T3/T04e .63ar, which would bolt right up and could make around 500HP. There is a shop out here in the states that is running to same turbo on the stock manifold (moded with an external wastegate) and custom down-pipe. They have a Apex'i S-AFC, 720cc injectors, 6puck, and FMIC and are making 450rwhp.
There is far more to a 0-100 time than the turbo, vehicle weight being the most obvious, followed closely by engine capacity.  So comparing a VLT with an R33 GTST really is a waste of time. :headbang:
To answer your question, I have an RB20DET with an RB25DET turbo on it and I wouldn't even think of taking it off and puting a VL turbo on.  The average power would suffer greatly, plus I would have to change a whole pile of stuff to get it to fit.  The big advantage of the RB25 turbo on the RB20 is it fits straight on.  Just swap over the wastegate actuators (the RB20 one has a higher spring rate). :)
how fast is that RB20 with the RB25 turbo on it?
i think this thread has moved it focus from a rb25 to a rb20. So to get things going. Is it a waste of time to bolt on a standard vl turbo onto a r33? Wouldnt the bigger exhaust housing and steel wheels make it an advantage over the rb25 turbo and thus more boost and power? The standard rb25 turbo has fantasic response but lacks top end power which would be useful from a vl turbo.
:D
We have found no noticeable difference between any of the RB25 turbos as far as boost, power or breakage is concerned. The compressor being plastic is a non isssue, it's the ceramic turbine that matters. And they all have it. :chop:
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
