When I read the post heading I thought WHY WOULD ANYONE BOTHER? :looney:
But then 7 posts later, all was revealed :idea:
So I gotta ask, why didn't you put the T4 internals in the R25 turbo?
SK - I got the turbo for the cost of a bog stock, NA RB30 long motor (~$350 from memory). It had already been modified by the previous owner, who had it on a VL. Far, far cheaper than modifying my existing turbo.
Wouldn't the aerodynamics be a moot point, with both wheels having been replaced as part of the rebuild? Or am I missing something?
PS, I mentioned that it had T4 internals in the first post :rofl:
I would have removed the T4 internals from the VL turbo and stuck them in the RB25 turbo. All you would have had to do was machine the RB25 turbine cover. Coupla hundred bucks with new seals and gaskets. Maybe worthwhile thinking about. :rofl:
so how efficient is the stock R33 turbo?
I have been wondering myself. Some say 12psi and others say 15psi.
Around here people are craving these ball bearing turbos and I could sell it for $350-400. Sell that and just spend another $200-150 on top of that profit and get a T3/T04e .63ar, which would bolt right up and could make around 500HP. There is a shop out here in the states that is running to same turbo on the stock manifold (moded with an external wastegate) and custom down-pipe. They have a Apex'i S-AFC, 720cc injectors, 6puck, and FMIC and are making 450rwhp.
There is far more to a 0-100 time than the turbo, vehicle weight being the most obvious, followed closely by engine capacity.  So comparing a VLT with an R33 GTST really is a waste of time. :headbang:
To answer your question, I have an RB20DET with an RB25DET turbo on it and I wouldn't even think of taking it off and puting a VL turbo on.  The average power would suffer greatly, plus I would have to change a whole pile of stuff to get it to fit.  The big advantage of the RB25 turbo on the RB20 is it fits straight on.  Just swap over the wastegate actuators (the RB20 one has a higher spring rate). :)
how fast is that RB20 with the RB25 turbo on it?
i think this thread has moved it focus from a rb25 to a rb20. So to get things going. Is it a waste of time to bolt on a standard vl turbo onto a r33? Wouldnt the bigger exhaust housing and steel wheels make it an advantage over the rb25 turbo and thus more boost and power? The standard rb25 turbo has fantasic response but lacks top end power which would be useful from a vl turbo.
:D
We have found no noticeable difference between any of the RB25 turbos as far as boost, power or breakage is concerned. The compressor being plastic is a non isssue, it's the ceramic turbine that matters. And they all have it. :chop:
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
