Hey,
got a highflow vl turb with t3 or t4 cartridge and some kind of modified rear housing.
i ran into dramas dummy fitting. ill let pictures explain.
as you can see straight up we have an issue with the dump pipe off on an angle due to the vl turbo mounted horizontal instead of vertical.
now im wondering without making a new dump or modifying the dump can i get it to fit properly.
as you can see if i hold it like so all the oil / water lines will line up, but if i modify the dump and bolt it straight up the oil return is horizontal not vertical.
any ideas... its asif i need to make some kind of t3-t3 90deg piece or if a rb30 turbo manifold would fit im not sure on stud pattern.
any suggestions would be kool, otherwise ill whack the stocker back on.
thanks,
dave
https://www.sau.com.au/forums/topic/305582-trouble-installing-turbo/
sorry i read it wrong...
have u tried rotating the exhaust housing?
No matter how u rotate the exhaust housing the dump will still stay on the same angle. might need to fabricate a new dump to suit mate.
for the oil feed it should be vertical so just rotate the 2 housings so that you get it in that position then get some braided oil and water lines, you then may have to rotate the turbine housing so you can get your pipe on your snail.
The most costly will be getting a dump pipe made to suit your turbo. probably around $400-$600 from your common exhaust shop.
im gona mod the dump myself. but ill try rotating it all. i knew you could rotate it but i was looking at the dump all the time going wtf !!!. but ill see how i go and then hopefully be able to mod the dump.
as i said this came off a R33 so i have no idea how the dump pipe worked out?
it would have had a custom manifold, possibly a high mount :) thats why the dumps like that
custom maybe, highmount no the dump would then be pointing at the bonnet. if a rb30 turbo manifold fits a rb25 thats what it would of been mounted on.
thanks for help, its on now, and im gona mod the dump on the weekend. factory lines fit, just needed the braided oil line. :down: the first time the rear housing didnt spin, but a whack with a rubber mallet fixed that. :)
if u put a peace inbetween the ex housing and the mani, the turbo would most likly hit the engine mounts when u put it in a car. Mod the dump, should b pritty easy, just cut the pipe off the flange, panel beat it to fit the right way and weld her up : D
nope. probs something like a hks cast low mount mani that has the flange facing down.
most important thing is to make sure the oil feed is at the top and drain is at the bottom, as close to vertical as possible
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
