Hey guys,
I was just asked a question by a forum member on how to swap the S15 Helical diff into the R32, so I thought I'd post it on here to help anyone else out.
A quick "Google" search will find plenty of articles explaining the benefits of the Helical diff centre. For me it seemed like the best choice, as the diff is awesome for street driving and does not wear out like viscous and clutch type LSD's tend to. The only down side to the diff is that it's not the best for drifting, and it can tend to open wheel if one wheel as zero traction (as the centre cannot detect any torque, so it doesn't know to transfer it to the other side)... Though I'm told that if you lightly apply the hand brake (when getting out of slippery spots) it should solve this problem and drive both wheels.
I'd purchased a whole S15 diff, with the half shafts, so I was hoping I'd be able to swap the whole diff over and not have to pull them apart. Unfortunately it wasn't that straight forward.
The S15 diff has the mounting holes is a slightly different position (due to the speed sensor at the front of the diff). In the attached photo's below the S15 diff is on the right.
So I had to remove my diff and pull it apart to swap centres.
My initial plan was to go with the 3.7:1 ratio from the S15, but after reading a few posts on here, I decided it would probably be too tall for what I was after. My diff was already 4.08:1, so it's taller than most.
After the diff was removed, oil drained and pulled apart. I unbolted the crown wheel from the viscous centre and then bolted it onto the helical centre out of the S15. I then reassembled the diff.
There are 3 shims that position the diff centre correctly (2 thin and one thick). As the crown wheel on the S15 diff is thicker than the R32 crown wheel, the thick shim had to be installed on the opposite side from when it was removed. It does seem quite tight to remove and reinstall them, but I had the correct amount of backlash when it was all done.
You then tap in the S15 stub axles, and bolt back on the rear cover. You cannot use the 5 bolt stub axles (from the viscous diff) on the helical diff centre, as they are different lengths.
I then reinstalled the diff onto the car, and bolted it up to the "6 Bolt" S15 half shafts.
I did this all by myself (with a little help from the wife) last weekend. The hardest thing is getting the bolts undone that hold the crown wheel onto the diff centre. A good vice and a breaker bar did the trick (my rattle gun didn't have the power).
There's a good tutorial on "R33 LSD shimming" in the DIY section, which explains how to remove the diff and crown wheel etc, and the rest you should be able to work out. (but if you have any dramas, just get in touch with me)
In all, I'm very happy with the upgrade, so if you can find an S15 diff and half shafts for the right price, go for it.
Ryno
Edited by Ryno
https://www.sau.com.au/forums/topic/305594-s15-diff-into-r32/
I assume you are referring to a torsen (torque-sensing) centre.
Helical is a style of gear cutting...
e.g straight-cut or helical (angle-cut)
Suppose if you came across a s15 setup cheap enough could be a good mod but still no match for a mechanical LSD in a race situation.
You are correct in saying it is a Torsen centre, however it is the "Helical" type. The other two main types of Torsen centres are referred to as "Parallel Gear" and "Planetary".
I'm not sure why everyone refers to the S15 Helical centre as helical and not Torsen, but that seems to be the case.
The setup cost me $250, so I can't complain about the cost.
As for performance, I couldn't be happier with it. My Skyline is my daily drive, so going with a mechanical centre or spool type (which may be better for the track) doesn't really suit the driving I do.
All I can say is, it's a massive improvement over my old viscous LSD centre. It gives off no diff noise, and behaves just as awesome going in and out of the driveway every morning, as it does when giving it the berries in a fast sweeper.
awesome write up!
I was going to put a S15 Helical into my R33, but thought the shafts wouldn't fit due to the output shaft differences, so I ended up getting a Nismo 1.5 way and now too lazy to put it in.
  • 1 year later...
Old thread..
So same applies with the R33?
The S15 mechanical centre can be swapped in easily enough? Would this be a reasonable upgrade to allow some limited drifting. The current VLSD seems to single spin all the time
I called a diff shop today re. other options: They told me I needed to source a plate type mechanical cenre for my diff so they could put in a Nismo centre. They said my model or some of the nissan's came standard with the plate type mechnical.
I take it the helical centre of the S15 is not a plate type LSD.. so I'm not sure what they are talking about.
I assume that since the VLSD can not be pulled apart they need a housing to place the nismo centre??
Any ideas?
Might be worth trying the S15 centre first with the R33 gear sets and see how that feels.
I'm thinking this may be better than shimming of the R33 vlsd.
I'm not sure what a plate type centre is? The LSD centre bolts into the crown wheel (the S15 helical and clutch type both fit). The important differences between the centres is the required shaft diameter and number of splines that exits both sides of the centre. AFAIK the S15 centres requires the S15 output shafts which are a 6 bolt type - so they won't bolt to the Skyline 5-bolt axles. So you need the complete half shafts with the centre.
Not sure if this will help.
im not totaly sure what you diff shop means but at a guess i think thay are taking about GTR diffs as they are mechanical from the factory and can be rebuilt using nismo parts.
otherwise if you get a nismo diff to suit a r33 gtst it comes as a complete centre. you just need to change over the crown wheel to the new center and pop it in. simple as that.
i belive a properly rebuilt Vlsd would work ok for a while. most people just shim them to be locked.
dont get a cheap mechanical diff if its a street car as they tend to be very noisy.
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
