I'm sure there's plenty of places around that'll take your money.
This is a good starter thread:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=30517
The HPI R34 project that's been a standard of conversion here is also a good idea of where to begin.
292rwkW was the last figure but I think they spent quite a bit more than what you got, I'm not trying to put you down, it's just that 250rwkW is a 'realistically economical' goal but then the money spent starts to spiral.
T.
https://www.sau.com.au/forums/topic/30561-r33-300rwkw-helpp/#findComment-619038
Robs car could go 300rwkw with pistons and a wilder tune as he is only running low boost etc.
GTS t VESPECs car is 300+rwkw on factory inturnals but he wants to build a motor so a blow up dosen't worry him so just copy one of these two guys cars but fit a set of Forged pistons.
https://www.sau.com.au/forums/topic/30561-r33-300rwkw-helpp/#findComment-619281
go the gtr atleast you know the rb26dett will handel more the power :( with out worring about it blowning up.
or maby a conversion ? thats always cheaper option but get the 4wd conversion aswell.
you'll have a lighter body any way.
i've seen a gtst with rb26 in it that pulls 400kws at rear wheels.
i know what i'd be doing with the money :thumbsup:
(sell gtst + mod money = gtr :)) (or rb26dett 4wd conversion :))
https://www.sau.com.au/forums/topic/30561-r33-300rwkw-helpp/#findComment-619284
blah anyone can do it with a gtr, there no fun there.
As meggala said my car is 95% finished to run around 300rwkw (atleast till the stock internals blow :thumbsup:) And if they do blow i will just re build with all good internals. From totally stock it will cost u around 15g for good bolt ons for 300rwkw without having problems and keeoing the stock internals alive for long as possible, minus internal work on the engine.
https://www.sau.com.au/forums/topic/30561-r33-300rwkw-helpp/#findComment-619334
If you feel like being different and don't mind the possible traction issues, then go with the GTS-t.
If you want good 0-100km/h times and want a daily driver friendly car then go the GTR.
It's upto personal choice.
Both have good points and bad points, so it's upto what you want in the car.
Personally, I wouldn't be able to pass up the 4wd :thumbsup:
A friend picked up a very nice 1994 R32 GTR for $28K. After getting to know the car, he's best 0-100km/h time is 3.9 seconds ! And that's quick in anyones terms. The car is running as he bought it ie. he hasn't done anything further to it.
J
https://www.sau.com.au/forums/topic/30561-r33-300rwkw-helpp/#findComment-619341
what mods are done to the gtr? coz 3.9 to 100 make it in the same league as a mclaren f1 road car
That was Andrew's (Ethan_R32) car.
Going by the dyno sheet that Andrew gave us it was running 240kw @ wheels at around 0.9 bar.
We test drove another GTR here in Canberra that just had exhaust and boost and it felt like a slug compared to Andrews ! Maybe who ever tuned/serviced it did a good job? Not sure...
I don't know all of the mods, but a few that come to memory are 3 1/2 ehaust (stock dumps), high flow cat, R34 N1 turbos, HKS adj cam gears etc.. Still running stock ECU though.... :thumbsup:
Anyways, a bit off topic.. sorry..
J
https://www.sau.com.au/forums/topic/30561-r33-300rwkw-helpp/#findComment-619356
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
