Guys,
I know that the actual aspects of ripping out your back seat and getting registered as a 2 seater has been covered, what Im looking for is your actual experiences using the same car on a daily basis.
Ie
Does it mean you cop allot more attention from the cops?
How did you retrim the spot where the seats were?
If you have a half cage, goes it obscure you vision when you reversing?
Did rego costs change?
These are all the things that Im trying to weigh up before I ditch the back seat and chuck a cage in. She's going to see the track at least a couple of times a year and in the last 6 years of owning nissan coupes, ive prob had 2-3 people , max in the back of the car (yes I have no friends) ^_^
Cheers
Mark
https://www.sau.com.au/forums/topic/305630-living-with-a-2-seater/
Guys,
Ie
Cheers
Mark
ran my r33 with no rear seats for over a year and had no issue with the cops. did not retrim the rear just took at the seats and left it like that.
If you rego as a 2 seater and are running a half cage there is nothing the police can do regarding it. Also it is possible to still have the rear seats in with a half cage.
Edited by Kaido_RR
The two seats in the back are pretty useless, when you do have the additional passenger or two all they do in the back is complain about how theres no room
I managed to have a root in the back, is there some achievement I unlocked for managing this?
Have you ever took the back seats out and felt how much they weigh?? Shit all.....
Also a street car with a roll cage? Why? Do you plan on rolling your car by pulling e brake turns as you exit the freeway? lol
As said above if its an all out track car it makes sense but if your driving more on street just leave the seats as is.
Just cut back on the hungry jacks! ;)
WORD
a roll cage does not only protect you if you roll your car but it increases the stiffness of the car. It makes a huge different it is noticeable!
If done correctly you should have zero issue with the police, even if you don't re-rego your car as a 2-seaters i doubt you will have an issue. A friend has been driving around his R33 with a half cage (strip rear, carpet in its place) and never had an issue. another friend running a full-cage again has had no issue and he has been stop by police afew times
Lol, internets certainly is totally serious business. ^_^
While the car will be a daily its also going to see a decent amount of track time, might even try to do this “drift” thing all the cool kids are talking about. The car is currently stripped so that I can remove all the factory sound deadening amongst other things. Ive always been a huge fan of the minimalist look and stripped bare interiors always get me going =P
Yeah I understand that but to me it don't make sense if you take the car to the track twice a year.
Would it not be more practical to get some Coilovers and some decent sway bars then spending money on a cage?
That would be much more effective if your looking for stiffness.
Cage = Cop bait
You are more likely to be asked to step out your car if they see a cage, so they can "have a look".
Just my point of view its just something to think about.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
