Well Im the proud owner of my first Skyline, a R33 GTS-t 2.5lt.
I haven't had it that long, but Ive come across my first issue, which is 2nd gear grinding, whether its from 1st>2nd or 3rd>2nd there is a considerable amount of grinding before the gear goes in. :(
It started happening yesterday when I was driving it home from work, I tryed changing down from 5th to 4th ato take a bend and 4th gear instantly grinded and wouldnt go in, after than I had trouble getting any gear in, so I slowed it right down and managed to get into 2nd with a little grind, then after that I could change back up the gears fine. But when I got to an intersection I changed down and when I got to 2nd it grinded again. Now it keeps grinding when I try to get into 2nd.
It does get there, but I really dont like driving it when this is happening, it feels like Im damaging it every time I have to go to 2nd. ;)
I took it out today to try double clutching it, and changing to 2nd at lower or higher rpms, but that didnt seem to help no matter what I did, altho by the end of my drive (~10mins) when the car was starting to warm up it seemed to improve slightly- much less crunch, but still bad.
Ive read a few threads here about the issue, so sorry for posting another, but Id like some more direct advice on what to do.
Ive heard of people replacing their spigot and thrust bearings, and some others replacing the gearbox oil, while even another person got thier ECU tuned and that fixed it.
Im just really hoping it wont be anything major, like a gearbox replacement or rebuild, because I really dont have the money or time for something that major right now...
Im getting the ECU re-tuned next week anyway, so I will have to speak to the mechanic about looking at the issue, but any advice or experiences you guys have would be appreciated so I can get a heads up. :D
https://www.sau.com.au/forums/topic/305640-yet-another-2nd-gear-grinding-issue/
I haven't had it that long, but Ive come across my first issue, which is 2nd gear grinding, whether its from 1st>2nd or 3rd>2nd there is a considerable amount of grinding before the gear goes in. ;)
It does get there, but I really dont like driving it when this is happening, it feels like Im damaging it every time I have to go to 2nd. :)
Im getting the ECU re-tuned next week anyway, so I will have to speak to the mechanic about looking at the issue, but any advice or experiences you guys have would be appreciated so I can get a heads up. :cool:
sounds like it "could "be as simple asthe syncro's ,which help the gears engage smoothly, when shifting..id take it to a good gearbox specialist and get them to give it a look.If they know about skyline boxes it would be good.....
Yeh I phoned my mechanic (who specializes in skylines) and that was the first thing he said it could be...
He'll have a look at it before he retunes the ECU (no point doing that if the syncro's are out)
Any idea of the costs I may be up for to fix that? If it is the issue...
I know the guy who had it before me recently upgraded the clutch and while he was doing that got the main bearings fitted in the gearbox, along with a few other things. So it makes me wonder why this issue has happened so soon.
Na sorry i have no idea on the cost to replace just the syncro's, I wonder why that pulled it down and replaced the b earings ,that sounds a little weird...Id "estimate" at least 800$ to 1500$,,but dont really no............l
Shit ok, not quite the numbers I was hoping for, we'll see what happens.
You said your clutch was recently changed? Maybe it is not fully disengaging and just needs adjusting?
Im hoping its something as simple as that, but if it was the clutch not fully disengaging then I would expect it to effect all gears, not just 2nd.
I have had a little trouble with 1st and reverse at times, but I put that down to my own error ;)
sychro cone 128 each,,,,i am doing mine,,hopefully get it done next week,,,, :)
Thats not too bad I guess + manhours of course.
The clutch is rather heavy, pressing it all the way down the the floor engages it better and there is a bit less grind, but its still pretty bad.
Im hopefully getting mine done next week also, depending on what actually is wrong. :P
Ill post the results here (and amount of excessive money ill probubly have to pay to fix this)
Im hopefully getting mine done next week also, depending on what actually is wrong. :)
when i drained the oil,i found a broken clip on the sump plug, by the time i pull the box apart,i found the 3rd,4th sychromess assembly has no clips left,,,,weird,,,,,it took me two days to pull it apart(i have to make my own bearing puller,,,i have never seen such a tool before,,,)
  • 1 year later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
