Well Im the proud owner of my first Skyline, a R33 GTS-t 2.5lt.
I haven't had it that long, but Ive come across my first issue, which is 2nd gear grinding, whether its from 1st>2nd or 3rd>2nd there is a considerable amount of grinding before the gear goes in. :(
It started happening yesterday when I was driving it home from work, I tryed changing down from 5th to 4th ato take a bend and 4th gear instantly grinded and wouldnt go in, after than I had trouble getting any gear in, so I slowed it right down and managed to get into 2nd with a little grind, then after that I could change back up the gears fine. But when I got to an intersection I changed down and when I got to 2nd it grinded again. Now it keeps grinding when I try to get into 2nd.
It does get there, but I really dont like driving it when this is happening, it feels like Im damaging it every time I have to go to 2nd. ;)
I took it out today to try double clutching it, and changing to 2nd at lower or higher rpms, but that didnt seem to help no matter what I did, altho by the end of my drive (~10mins) when the car was starting to warm up it seemed to improve slightly- much less crunch, but still bad.
Ive read a few threads here about the issue, so sorry for posting another, but Id like some more direct advice on what to do.
Ive heard of people replacing their spigot and thrust bearings, and some others replacing the gearbox oil, while even another person got thier ECU tuned and that fixed it.
Im just really hoping it wont be anything major, like a gearbox replacement or rebuild, because I really dont have the money or time for something that major right now...
Im getting the ECU re-tuned next week anyway, so I will have to speak to the mechanic about looking at the issue, but any advice or experiences you guys have would be appreciated so I can get a heads up. :D
https://www.sau.com.au/forums/topic/305640-yet-another-2nd-gear-grinding-issue/
I haven't had it that long, but Ive come across my first issue, which is 2nd gear grinding, whether its from 1st>2nd or 3rd>2nd there is a considerable amount of grinding before the gear goes in. ;)
It does get there, but I really dont like driving it when this is happening, it feels like Im damaging it every time I have to go to 2nd. :)
Im getting the ECU re-tuned next week anyway, so I will have to speak to the mechanic about looking at the issue, but any advice or experiences you guys have would be appreciated so I can get a heads up. :cool:
sounds like it "could "be as simple asthe syncro's ,which help the gears engage smoothly, when shifting..id take it to a good gearbox specialist and get them to give it a look.If they know about skyline boxes it would be good.....
Yeh I phoned my mechanic (who specializes in skylines) and that was the first thing he said it could be...
He'll have a look at it before he retunes the ECU (no point doing that if the syncro's are out)
Any idea of the costs I may be up for to fix that? If it is the issue...
I know the guy who had it before me recently upgraded the clutch and while he was doing that got the main bearings fitted in the gearbox, along with a few other things. So it makes me wonder why this issue has happened so soon.
Na sorry i have no idea on the cost to replace just the syncro's, I wonder why that pulled it down and replaced the b earings ,that sounds a little weird...Id "estimate" at least 800$ to 1500$,,but dont really no............l
Shit ok, not quite the numbers I was hoping for, we'll see what happens.
You said your clutch was recently changed? Maybe it is not fully disengaging and just needs adjusting?
Im hoping its something as simple as that, but if it was the clutch not fully disengaging then I would expect it to effect all gears, not just 2nd.
I have had a little trouble with 1st and reverse at times, but I put that down to my own error ;)
sychro cone 128 each,,,,i am doing mine,,hopefully get it done next week,,,, :)
Thats not too bad I guess + manhours of course.
The clutch is rather heavy, pressing it all the way down the the floor engages it better and there is a bit less grind, but its still pretty bad.
Im hopefully getting mine done next week also, depending on what actually is wrong. :P
Ill post the results here (and amount of excessive money ill probubly have to pay to fix this)
Im hopefully getting mine done next week also, depending on what actually is wrong. :)
when i drained the oil,i found a broken clip on the sump plug, by the time i pull the box apart,i found the 3rd,4th sychromess assembly has no clips left,,,,weird,,,,,it took me two days to pull it apart(i have to make my own bearing puller,,,i have never seen such a tool before,,,)
  • 1 year later...
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
