Ok, Heres my problem.
Today (Boxing Day) I started my car and took off fairly hard bringing first gear up to about 6000, I then proceeded to change to 2nd hoping for that nice wheel spin can be achieved from this. Alas I was not greeted with wheel spin but a great loss of power like bad turbo lag instead.
Now to my problem, ever since this every time I get the revs to 3000 in any gear from 2nd up, the revs suddenly jump to 4500 and then back to 3000.
There is no jolt when this happens, just an over revving laggy engine.
Also there is now a slight ticking noise coming from under the left hand side of the bonnet when the car is idling.
I am thinking that it could possibly be a blown turbo gasket? But it has all happened so suddenly after me being stupid and not allowing my car to warm up correctly.
Could this be the cause, What are everyones thoughts?
BTW my car is stock except a 3in cat back.
Any help is greatly appreciated as I am fairly new to the world of turbo cars, and my mechanical knowledge of cars in general isn't exactly in depth, so go easy on a newby
https://www.sau.com.au/forums/topic/30565-please-help/
Ticking sound from the around the turbo certainly sounds like a blown turbo gasket, I had similar problem a while back.
If it is, its not an expensive fix.
Poke your head in the pasenger side of the engine, you may be able to see the problem.
Dont go flogging it, cause if its the gasket you dont want more pieces of the gasket breaking off and flowing through the various parts of your engine.
https://www.sau.com.au/forums/topic/30565-please-help/#findComment-619200
Thanks mate. What exactly am i looking for with a blown gasket. As I said I am a complete newby to the world of turbos, but I am doing my best to learn about them.
I know where the turbo is located but what exactly would the blown gasket look like?
Any help is greatly appreciated, as none of the mechanics in my area that I would trust to work on my car are open due to the holidays.
Thanks in advance.
https://www.sau.com.au/forums/topic/30565-please-help/#findComment-619264
Sounds like it could be a slipping clutch to me?
https://www.sau.com.au/forums/topic/30565-please-help/#findComment-619804
Trying to decipher your problem as a couple of the other guys have stated it does sound like it could be your cluth that is the problem.
But just to clarify something for you you say it feels like and over-revving LAGGY engine
Over-revving does indicate slipping clutch ( you can check this by loading the engine in a higher gear at relatively lower speeds) caution though be careful not to do to much damage
Lag is the lack of REV's or "pick up" when you accelerate theoritically opposite ends of the spectrum.
but anyway good luck.
https://www.sau.com.au/forums/topic/30565-please-help/#findComment-620225
thanks for all the replies everybody (and for the definition of laggy).
Sorry for the late reply computer problems, it never ends!
As it turns out the clutch was the problem, took it to autosport and they had it diagnosed about 2 seconds after getting into the car.
Anyway, it is now replaced with a heavy duty item and is going better than when I first bought it. It is even creating up to 10 psi boost (only could get 7 before new clutch).
So in summary thanks for the help, and these forums have now become my official home away from home. Such a wealth of valuable information!
cheers
https://www.sau.com.au/forums/topic/30565-please-help/#findComment-630935
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
