Hi , i have my stagea 260rs for sale it has 70ks 18 inch bbs wheels apexi exhaust, coilovers very hot and fast,very very clean came in at a grade 4.5 and has been kept that way ,this car was a personal import after a very long search for a genuine low k clean as a whistle car,only down is i took the front lower lip off cos the misses took it shopping and you can probably guess what happened? selling very very cheap need the money, $18000 or looking to swap for a 4x4 dual cab, or landcruiser ,nissan patrol something along those lines
PHONE 0450977026
Edited by SUN32RISE
PHONE 0450977026
running stock boost never boosted ,arc airbox, open to offers trades not price
Edited by SUN32RISE
got the front lip mate?
put it on carsales man...
go back to stock and sell it that way
i did that coilovers are worth a grand, those wheels will get 1500 within a week
exhaust is of the highest caliber also!
PHONE 0450977026
also forgot to mention has 5 months reg
PHONE 0450977026
Willing to trade for cheaper car let me know what you have
offers?
These cars are by far the best I've driven!! I had one but since gone to an rs4 tow beast... Kicking myself for it:( coil overs on this car as well over a grand 2nd hand, the wheels are 1500 easy, zorst 800 or so.... A huge barging to be had here!!! Brembos the lot!!
Good luck mate :) I've got a mint rs4 waiting for u :)
  • 6 months later...
  • 3 months later...
if the stagea is for sale would u be interested in a swap for a extremely clean R33 Series II with low km's ... never been boosted
best regards chris
  • 2 months later...
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
