Well, after picking up my 1996 GTSt from auction in Japan in mid-October, it's now finally sitting in my garage, registered, complied and good to go! (oh, and fully insured too hehe)
Few delays along the way, nothing major..compliancers opened up on Boxing Day so I could pick up my ride, how nice of them!
Still got to get my 3rd tier inspection done, but that's pretty much a formality.
So I'm finally looking forward to seeing a few of you ppls around, especially those out Penrith way! If you see a black man driving a white R33, don't call the police, wave! hehe (that's me btw, don't take offence!)..
https://www.sau.com.au/forums/topic/30569-yay-car-ready/
Skyline @ 16? Hehe that's cool, although do you have power-weight restrictions over in WA?
$4100 isn't too bad either - I got quoted $5000 to insure my 18 yo brother.
/added - Oh yeh, I just remembered, I'm in Sydney. That pretty much explains the diff. Damn. :thumbsup:
https://www.sau.com.au/forums/topic/30569-yay-car-ready/#findComment-619306
I just took my car out for it's first decent drive..I'm speechless. The acceleration is crazy (as a reference I've only driven Taragos and a Mazda 1.6L Protege in the past)..
Can't believe it, and you ppl with GTRs out there..whoa. Respect!
Buying it was the best decision I've made all year!
https://www.sau.com.au/forums/topic/30569-yay-car-ready/#findComment-620151
Got it thru Prestige..had no problems with the service from Geoff, no delays, no dramas.
3rd tier inspection - Vehicle Identification Inspection, as the RTA calls it. As far as I know some blue-slipped cars that don't come from a dealer have to go thru it, just to check that the car isn't dodgy - eg they match the compliance / vin / engine numbers, etc.
Did a search about this too, and it seems that defect inspection may / may not be conducted..not that I have anything to worry about, being a STOCKER and all haha.
njs - Yeh I've revised down slightly what I wanted to do, mods wise. But like you said, I'll get used to it. I give myself three months before I start thinking..
https://www.sau.com.au/forums/topic/30569-yay-car-ready/#findComment-622152
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
