Guest Boxhead
hhmmm.. thats a good idea, now where do i get some petrol from.. ahhh i know,,, the lawnmower.. did anyone know which petrol works best???
also.. this is sorta off topic but not.. my mate told me that if you wipe yoru windscreen with newspaper and say windex, or glass cleaner, it will leave no marks.. so yeah, next time i was the car which willbe in months.. i will do that.
https://www.sau.com.au/forums/topic/3057-windscreen-wipers/#findComment-52926
Are you sure its the chemical in the newspaper?? i thought any fine paper will do.....like the little packs you can get for cleaning eye glasses.
Will try some petrol, but i think the trouble might be deeper than the blades. Any one used the windscreen products you apply to the glass, meant to make water bead off really well.
https://www.sau.com.au/forums/topic/3057-windscreen-wipers/#findComment-53011
it really helps if u use some sort of windscreen product to clean it which makes the water bead. similar to wax for the windscreen. then the water just wooshes off :)
after i had my car detailed the windscreen wipers worked a treat coz the water would just bead on the windscreen and the wipers just cleared it off.
https://www.sau.com.au/forums/topic/3057-windscreen-wipers/#findComment-53286
rainX is good *****... the guy at repco intro'd me to it, used it ever since, also use this compound which you add to the water reservoir and it prevents streaking, fogging and improves beading (for extra measure) but my wipers are long gone, and the leave trails all over. (not that I have to use em coz the water jus slides off)
https://www.sau.com.au/forums/topic/3057-windscreen-wipers/#findComment-56770
  • 2 years later...
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
