Downloading Software
bozodos
 Share
Torrent speed is limited by the seeders... if you dont have enough seeders = their max upload speeds...
With rapidshare (co-incidentally with hamachi network with other Internode users also) I was maxing my speed.... there is no way you can compare torrent to a direct DL. Especially when you are downloading from Aust sites...
well i'd thought i'd had it optimised as best as i can, i have a billion 7300g, best router I've used so far, got any tips ash?
Without looking up the router specs to match your torrent client - Nope :D
If i get bored i might. What torrent client you using?
Also ensure the latest firmware is on there, often that can make all the difference.
I max my speed out with torrents, i can have 10 people seeding to me.
It's not the number of seeders, it's the swarm speed that matters.
500 people upload @ 1kb/s on one torrent... yet 10 people upload @ 500kb/s on the next - guess which is faster :banana:
I can see the same speed via torrent as i can direct download from Aust sites.
Only issue with torrent is it takes 1-5 mins to register and "speed up" once links are created. Usually im running max in under 1min.
You don't always get a large amount of seeds to dls though...
500 x 1 or 10 x 500 :D
I dunno, torrents don't suit the projectw use so its useless to meh =D
Download skinnier chicks... they won't take up all the bandwidth
They might get hungry for some if you have it spare or worse yet they might have a memory leak :banana:
using utorrent, hmm well I remember back in the day having to create a static IP for my pc and manually setting up port forwarding on a linkysys router just to get torrents working properly, surely that's not going to make things any faster in this circumstance!
interesting comment about the firmware, I was under the impression that it wouldn't do much at all!
Ok 7300g
Max connections you want is around 750 or the router is going to shit itself much above that as it has around 800-1000 connection limit or there abouts.
If using utorrent you need to decide how you are going to download.
1 Torrent at a time - set max connections per torrent to around 650
More than one torrent - divide 650 by the amount of torrents you want to have running
There are some other things you can change, but im assuming you don't have any issues at the moment with drop outs and so on.
If you do, post up. I'll have the fixes for it :P
 Share
    • Welcome.  Glad to hear that you have gained some knowledge that has helped you. I believe the only fix for the power steer belt is an electric conversion with a Holden astra pump. If you get a chance, post pics of your car, please. 🙂
    • Just ordered those bosses, hopefully that does the trick thank you very much everyone for your replies it's really appreciated
    • to have this type of adjustment possible with a curve as I wish, what budget (engine) should be planned?
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
