Gram Lights 57 Pro Maximum
Small analogue delay circuit with a relay. Just need a trigger, say, fuel pump running for more than 5s or so? Or, you could go full mental and write a sketch for an Arduino.
I don't know, honestly. Easier to just use a CAN wideband with the Haltech so you can get the ECU to control the wideband in the manner described. -
Update time! The JZX110 had some maintenance needing to be done, so a lot of the seals with replaced to fix some oil leaks. Also used this opportunity to whack on a front mount that I'd bought some time ago. I also finally got the rear lip painted and fitted. I then got the exhaust done. It's just a catback for now. Custom made 3" stainless with a turn down. I could have a tip coming out, but it will require cutting the rear lip and possibly the bumper itself. So far I do like and it's made the car a little more zippy. Close out with some nice pictures of the cars and a sneak peek of what's next.
