Hi compnerd, 10 mm (with standard PCD) needs a little bit of die grinding of the head to clear the lobes and set of valve springs designed for that lift. Standard valve springs won't handle that lift, they coil bind when set at the right seat pressure.
Unless you are unbelievably lucky, you will have to reset the tappet clearances with different thickness shims. If you haven't done this before, it can be a long and teadious job as you have to remove the camshafts every time to fit a different thickness shim. You can either grind the standard shims (if they are too thick) or do the measurements first and then order the right thickness shims.
I assume you are aware that 280 degree camshafts (particlularly the inlet) are fairly lumpy? We wouldn't consider using them in an engine with less than 700 bhp. The extra horsepower gained under that, is simply not worth the off boost lumpiness.
Hope that is of some help
Happy New Year
g'day sydney kid,you said these cams would not be favourable under 700 hp,I havent set the engine up yet,and I havent really had much to do with gtr's,I have a pair of hks2540,hks f-con pro v 280 cams+springs,vernier cam gears,what sort of power should I expect from this set up? how will the fuel system cope?
regards stuart
  • 4 weeks later...
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
    • Oh, yes. If you connected it to the manifold your first drive would be very eventful. Very shit. Very interesting. Perhaps take a video if you feel the need to see. Terminating the breather at the top of the bellhousing is normal/stock. Some gearbox lubes (hello Redline Shockproof) like to foam up a bit and require the breather to be extended up higher, so you don't get spots of smurf jizz staining the floor under your car. Mine is thus right up behind the head. Make sure you fit a u-bend at the top so it points back downward so that dirt and schmutz has a harder time getting into it.
    • Cheers for the replies. So i don't connect it to the manifold I just run the hose high up on the firewall?
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
