Does anyone have anything useful to say about this relatively cheap HKS 2.8 kit that appeared late last year?
the one that can use stock conrods if you wish.
"step zero" I think it is called, and a stock redline of 8000
as far as I know the price is about 400,000 yen. Which is $5k. Plus $? for install.
Anyone know what the $? usually comes to..
https://www.sau.com.au/forums/topic/305766-hks-28-step-zero/
In addition to increased displacement effect of 2.8L, STEP ZERO is the best solution for engines that require better response.
The target maximum revolution is best for stock or GT-SS turbine with greatly improved response.
The affordable price allows usage just for engine overhauling.
It is optimized for target turbines and rpm.
Although it is full counter, the ultra lightweight design achieves quicker response than ordinary STEP1 or STEP2.
Full counter design decreases load on metals.
The pitch of both connecting rod ends is not changed as ordinary kits and stroke is adjusted by piston height.
This design is less side pressure, less friction and more durable than other manufacturers' 2.8L stroker kits that change the pitch between the both ends.
・Newly designed φ86.5 piston.
Piston bore can be selected depending on engine block condition between φ86.5 and φ87.0.
・Proven MADE IN JAPAN (HKS in-house production).
- http://www.hks-power.co.jp/db/product/file...4-AN009_012.pdf
Couldn't tell you an exact price but I assume it would be no more then the HKS Step 1 / Step 2 kit.
Tangomatt has a HKS 2.8lt kit in his R34 GTR, best ask him and he can let you know whats involved and pricing.
His HKS 2.8lt was put together / tuned by Ben from Racepace.
Well your RB26 will become a lot more responsive and the revs will just blast straight up, no sweat.
Will have plenty of pull too!
Pure 'sleeper' mod and will surprise a lot of ppl.
You thinking about doing a 2.8lt conversion?
What's your goal?
Its just basic kit that is purely for response while using GT-SS turbo's or alike. You'll get around the 400ps (dont know what that is in HP or Kw's) but I'll be at HKS on the weekend so can get more info.
I saw them a few months back and asked about them and they reckoned it was just upgrade kit for more performance, lighter crank and revs more quickly but 8000 rpm max. I'm pretty sure its not a forged crank, just lightweight counter.
They made them up here because everybody is broke and doesnt have the coin for the Step 1,2 and 3 kits !!
400 PS = 394.52 HP
400 PS = 294.20 kW
Sounds good your heading to HKS on the weekend.
Please do tell us how you go.
400ps is roughly 293kw... which I assume u mean at all 4 wheels?
I would have thought that is pretty conservative estimate with GT-SS turbo's and supporting mods..... let alone adding the 2.8 kit??
Dont quote me on that figure as gospel as when I was talking to my mate at HKS about the 2.8 build on my car at the time and was wondering why they were so cheap compared to the Step 2 kits.
There's a few configurations on the kit with the basic starting at 400,000yen.
Why only 400ps?
considering the standard GTR crank and rods can see almost 600ps then it must be the piston design holding this kit back? maybe they are light cast items similar to stock not forged
that or the crank is significantly lighter (and therefore weaker) than the standard crank?
Ok my mistake !!
Was just on the blower to my mate at HKS and Max power rating of kit is 600PS !!
sorry for the misinformation.
Crank is full Counter weight only.
Forged pistons and Rods.
Use of N1 Oil pump is fine as limited to 8000rpm but you cant be too carefull so upgrade of oil pump is up to customer.
Highly responsive motor with great torque !!
Ok my mistake !!
600ps at engine or wheels??
Ok my mistake !!
600 PS = 441.30 kW
That sounds more like it :P
Good to hear that elrodeo666.
I love a great responsive RB26 as the experience is pure awesome!
The Japanese rate it at the wheels but their dynos are notoriously number happy.
Regardless its pretty good bang for buck.
My 2.8 Step 2 build here was bloody expensive !!
So is it a lightened factory crank by the sound of it?
If so - that would be quite a nice saving.
I would say the RPM/power limit would be relating to things like rod bolt choice and so on, which are easily solved
  • 7 months later...
Just bumping an old thread instead of starting a new one.
Is anyone using the step zero kit?
It says that it will suit someone running GT-SS or stock turbos and only revving to 8000rpm. Is this HKS under rating their product or is it really that weak?
I would be interested to know if it would be capable of around 600hp with a T04Z and 8500rpm with ARP bolts all round and all the good necessary hardware.
Thanks
  • 6 months later...
I am looking at 2.8 options myself at the moment, and a tuner responsible for the engines in some of the fastest time attack cars in Japan tells me they are using the Step Zero in the majority of their cars, all of which are producing at least 650PS and have yet to find the limits of the kit - Interesting feedback
It appears the Pistons and Rods included in the Step Zero are the same as those included in the Step 1, leaving the main difference as the crank
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
