I am looking at 2.8 options myself at the moment, and a tuner responsible for the engines in some of the fastest time attack cars in Japan tells me they are using the Step Zero in the majority of their cars, all of which are producing at least 650PS and have yet to find the limits of the kit - Interesting feedback
It appears the Pistons and Rods included in the Step Zero are the same as those included in the Step 1, leaving the main difference as the crank
Let us know how you get on Blitz, interested.
So what is acutally different crank wise from the Step0 to the Step2? Is it just a lighter crank; is it still fully counterweighted?
interested as a future upgrade, hopefully will tally up nice with the my -9 turbos upgrade later this year
noob questions, will this KIT comes with all the bits that normally constitute a "RB26 mid life freshen up :) "
so that all you need is oil pump, coil pack,water pump,etc
does anyone know budget for install of such a kit
GOAL - only after super responsive Street GTR with loads of torque, Power around 280AWKW range, so not much
Here is the HKS spec sheet:
21004-AN009_012.pdf
There are a two different kits available, the full kit including crank, rods, pistons and rings/pins, and the piston-crank kit designed for use with factory rods, which only includes HKS counter weight crank and Pistons.
Both options available with either 86.5 or 87mm pistons
Will do, the kit has been ordered so will be sure to post up some pics and details once it arrives at the workshop :)
Looking forward to your results Nick....
Did you go 86.6 or 87mm pistons?
Did you get the kit with or without rods?
Very tempted at the moment as the kit without rods works out to half the price of the step 2 kit.
Jack,
I was informed by one of the HKS Pro Dealers in Japan that the Step Zero uses the same pistons and rods found in the Step 1 and 2.
I ordered the Full Kit with 86.5mm pistons which is going into a new N1 block :)
I can't find pricing for the step zero.
Is 400,000 yen for the full kit or just crank and pistons. I noticed the full step 2 kit through nengun is close to $9K.
Does the crank and piston kit still come with the rings and pins?
So your still going to use GTSS Nick?
Hey mate,
The 400,000 Yen is the 'Full Kit', so Crank, Rods, Pistons, Pins, Rings
The 'Piston-Crank' kit is significantly less but doesn't include rods.
Also worth noting for anyone questioning the quality of the kit, is all components are Japanese made.
I already have a new set of GT-SS's at home, so being that the Step Zero is designed for response, im going to chuck the GT-SS's on and see how far I can push them!
At that price it still works out to ber quite an expensive excercise by the time you pay freight, tax's etc.
I think the nitto 2.7 with the billet counter weighted crank might be a better proposition.
They claim it will rev to 12,000 rpm which is a shit load more than the hks zero setup.
  • Like 1
I have seen the Step Zero Full Kit as cheap as 357,000 yen (Approx ~$4,279.00 AUD) - Whats the best price you have found on the Nitto 2.7?
CJ-Motor lists them at over $9,000
Hi Octane lists them at over $7,500.00
Unique Autosports lists them at $8400.00
For a car being built for track purposes, the Step Zero is a fantastic kit, and the power, response and ultimate track performance that some tuners in Japan are achieving with this kit speaks volumes and is more than ample for my application. If I was building a drag car requiring the higher rev limit, it would be a different story.
Hey mate,
Should be good to see!
Any idea on the price of the crank / piston kit?
Rohin.
You're probably right Blitz, I was quoted around the 7 kay mark when i first enqired about the nitto kit.
The zero setup would be somewhere in the vicinity of 5500/6 kay landed so yeah, Its a fair bit cheaper but as you say, if you wanted to rev it the nitto would be the way to go.
how much labor $$ would we be roughly looking at onto of the $4.5k to get it all together? assuming you have a running rb26
Very interested in the labor cost
at the of the day, you need to budget and at least have ball park figure
how much labour $$ would we be roughly looking at ontop of the $4.5k to get it all together? assuming you have a running rb26
It all depends on who u get to do it, your basically rebuilding ur bottom end so wouldn't be cheap. If I was doing it I would get another short block and get it done, that way once it's ready pull the engine out take the head and sump off, put it all back in and retune. That way the car is off the road not as long, and plus you could sell your short and recoup some costs.
quoted for truth
if you have a running rb26 leave it! anyone who pulls a perfectly fine 26 out to build it is mad
building a bottom end is the same whether it was running fine or not (excluding putting a rod out the block of course)
call racepace and get a quote
My thoughts exactly and spot on the path I am going down.
I still need to sort out my sump and oil/water pump, plenum and a few other bits, but the block and internals will all be brand new, as will the head and associated hardware which is being setup, ported and assembled by a tuner in Japan then being sent over to me, so the target is to fully assemble the replacement engine and when its ready simply do an out with the old and in with the new swap
^ thought about this as well - reckon it's cheaper to get it put together there and sent out? I was wondering if you got a big workshop to do it, whether they could get parts cheaper than we could
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
