Which site sell the rods for 1000, Beer baron ?i can get a 2.8 crank from my turner, hes orderd afew custom 2.8 kits of his own,il go with his 2.8 crank,tomei rods,mahle pistons,maybe tomei piston if they;re cheaper then the mahle's,
Who's the tuner?
HKS themselves say go step 2
This step 0 kit really is for small power outputs - given that the stock nissan cranks can go way past the power level of this kit, i dont see why anyone would buy it unless they want to be able to say they have a 2.8 - even then its the poor mans budget option
You already know HKS are very conservative with their power figures and this being the same material as a stock cast crank it will take the same amount of punishment except giving extra cubes. Don't know how you can possibly think it's not worthwhile?CheersMarty
I would expect this kit is to give you 2.8L response. I don't think it is designed for huge power or anything. Even HKS recommend use of GTSS turbos so max expected. power would be 360rwkw?
Sounds to me like a great idea for people who want the 2.8l response but don't want to spend huge dollars for step 2 engine.
This kit sounds like it would make a great street engine!
Edited by gtr fan
stroker kit or a Rb 30/26 , ive heard people have problems with the block sitting 50mm higher, any thoughts.
It's 38. Depends on what car you have. R32 there is a little more fiddling than a 33 or 34. I own a 2.8, give me a 3.0 anyday. That should answer it!
I wouldn't have a problem sending it over a thousand horsepower, I cant count on my hands or toes how many cars here and Japan have done it on the stock crank, so I don't see how having another 200cc balanced crank is going to make it worse, quite the opposite I would suspect.
Please, go do that and tell us how you go :)
Yes I'm aware HKS (well, all Japanese companies) err on the side of caution with part ratings whereas here we just push them until they break or another component reaches its limit.
I'm a strong believer in the stock cranks being good parts and yes they've been proved over and over by various builds/shops so as for the actual power level this will deal with - well someone needs to push one and see - there was a lot of keen comments earlier in this thread but it seems to have died down which is a shame, but when you're comparing the step zero to other offerings out there I personally don't see it as worthwhile because IMO if you're going to spend the money and build an engine with a cast crank you may as well get the best increase for the money spent so unless you have to stay with the stock block for some reason, skip 2.8, go 3L and save some money.
When I blow mine up this will be one of the front running options, not having to f**k around with all the little things that you need to get a 30 in the car.
Drive a 30. That will change your mind very quickly!
would you loose much of the rev limit on a 30? i know with the stokers its limits you till about 8k if ive read correct. i aussume the down low torque would be quite nice tho, with some suitable turbos you would have a very nice resposnive street machine.
You really do dribble some crap sometimes Stevo.
And back to the factual basis of this thread for those that continue to pm me asking me about my build.
Right now by bottom end is in the process of being balanced - I have the Step Zero complete kit, with crank, rods and pistons all of which will shortly have a new home inside a new N1 block, with a brand new custom specification head setup which is being ported built and assembled for me in Japan
There seems to be a large number of people that are very keen to see the real world results of this kit, and get an idea of its limitations. I am not aware of anyone else in the country that is running this kit yet but obviously that may be wrong. I would like to point out I was looking at the Tomei 2.8, HKS Step Zero, 1 and 2 2.8, and Nitto 2.7 strokers while deciding, and my decision was not purely dollar based, but rather it was centred around what i wanted out of the car and its application which is first and foremost circuit racing where response is critical, not high rpm. Obviously at its price point its a very attractive option for what it offers - The Step Zero is designed specifically for use with GT-SS type turbos, not big singles, and I was pushed over the line after seeing the results ATTKD has achived. Incidently, ATTKD runs this exact kit in the majority of its Time Attack cars, and it is responsible for some of the fastest Time Attack cars in Japan - That was enough for me.
ATTKD/HKS advised that the pistons and rods included in the Step Zero are the same as the those in the Step 1 and Step 2, so the crank is the only difference and as Martin has posted above, HKS is always very conservative in their power ratings. Just how conservative is something I full intend to explore as the car will be setup with somewhere in the region of 500-600awhp initially, and I may well up this later and see just how far the internals will go.
Hopefully I will have some photos to put up soon.
Cheers!
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
    • I get into huffs with people when I suggest the MX5 looks so much better as a coupe than it does as convertible. Pretty sure I don't prefer the convertible version of anything. Good job on the hardtop! The next buyer will appreciate.
    • IMO wrap does have its uses, but like you said, quality wrap, and professional installation, would probably cost want a quality paint job does, but, the paint, if maintained, is basically for life, and much easier to touch up if required  In other news: it's pissing down here, with thunder, lightning and only some small hail "at this stage", luckily all "my" cars are undercover  I've also been contacted by a guy in Newcastle about the SS, he said he will come down next weekend for a look, we'll see how that transpires I guess 🫰
    • Nah, I'm not an a-hole, ha ha!   I do like the colour match. Some of the carbon fibre wraps are quite freaking horrible. There's one a local company I know uses, and it looks damn good! Also very very expensive per metre to buy! ha ha ha It might be cheaper to respray the roof than use the good CF Wrap, ha ha!
    • Please noooooooo 😭 As for wrap, no thank you mate, I've seen and used "carbon fibre" wrap before, and for these hard tops, they look soooo good when colour matched Like this >>>
