Heyya doing people!!!!!!
Right my heart set on building a very fast R32 powered by a RB22!!!!
Right first off lets start by saying this car will have to drive from Ireland to Germany to the RING !!!!!!! once or twice!!!and be used at weekends for fun n games! but truly is gone be a track car!!!!!
My plan is to ! Rebuild my perfectly working RB20 cruently at 300BHP at fly! to something with a bit more power!!! would like 350+ at the wheels, im unsure of what turbo will get me there but its not all about the figures!!!!!! Im looking for something which will be track focused, good power , and plently of RPM rang so i can used the power on the track!!!! any ideas??????
Engine rebuild from the bottom up will consist of:
Regrind crank.
ACL big end bearings + (was going to go with rods too but tuner told me there good for 500?)
Apr bolts
forged Wössner pistons
Rebore for 2.2L
Cumbustion chamber enlarged for 2.2 bore!
metal head gasket
oil gallery orifice + leak off to sump
N1 water and Oil pumps
Considering using GTR valves(input please)
abj pullies,Soild lifter, GTR cams, supertech double valve springs
Plazmaman Inlet manifold
Fueling wise im unsure of i have 444cc injectors + should uprate to external pumps or twin intank pumps?
Guys any input will be helpfull! please help the IRISH guy!!!!
Many thanks Chris
https://www.sau.com.au/forums/topic/305784-rb20det-tuning-and-options/
Not quite sure where you are going with this build but these threads might help. They all deal with increasing the capacity of a RB20. Read the stickies in this forum for heaps of information on suitable turbos. You will probably have to think about a gearbox upgrade as well. Good luck with it.
http://www.skylinesaustralia.com/forums/Rb...tml&hl=rb24
http://www.skylinesaustralia.com/forums/Pr...tml&hl=rb24
Well r32 NA are hard to come by over here tho ill look into it!!!! and i want to keep RB20 yes i know ! rb25 flow better and would be easyer to start from there! But this is about keeping it a RB20!!! plus then you have to pull it apart n start agian -1000euro
And yes Rb25 box here for new build!!!! the rest of the car is done just need enine now!
Edited by irishGTSr32
Dude, if you want 350bhp+ using a rb20.... there's going to be lag. You'll have to build it to rev.
Go the TD06L2.
If you want to keep the rb20, use a rb26 crank and rods with custom pistons. Keep the bore as close to stock as you can.... bored out rb20's seem to split blocks regularly.
Port the head, thow some rb26 cams and solid lifters.
Then throw as much boost and fuel at it as you dare...
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
